05-14-2020, 05:41 PM | #1 |
Very stiff brakes
The brakee have gotten very stiff and I only get about 10% braking capability. I checked the brake fluid and the reservoir for the rear brakes was empty. I added fluid but it made no difference. Do I have a bad master cylinder or a bad booster?
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
05-14-2020, 06:06 PM | #2 |
Moderator
Re: Very stiff brakes
If you have removed the rear drums and confirmed that the rear wheel cylinders are not leaking, then I suspect a collapsed rear flex hose.
That fluid went somewhere... did you find the leak? Also, did you bleed the brakes after adding more fluid? |
05-14-2020, 07:15 PM | #3 |
The stiff brakes sounds like a bad booster or leak in the connecting vacuum hose.
The missing fluid also needs to be tracked down. 2nd on pull the rear drums and inspect. Might remove the front tires and inspect the rotors and calipers for good measure. Did the brake warning light come on? If not, yet another thing to troubleshoot. It should have came on from the empty MC half. |
05-14-2020, 08:01 PM | #4 |
Thanks for the replies. I bought a new brake booster and master cylinder. The brake booster is original and master cylinder has about 150k miles on it. I've had master cylinders leak fluid before so maybe this will fix it.
I did check for vacuum but have not confirmed if wheel cylinders are leaking. |
05-15-2020, 03:11 PM | #5 |
Update:
Still the same issue after replacing the brake booster. However, rear brake fluid is coming out of the left rear brake. I ordered a new rear brake cylinder. Does air in the rear brakes lines prevent the front brakes from working? |
05-15-2020, 06:48 PM | #6 |
Your proportioning valve will shift over its internal spool and isolate the rear or front brakes if fluid is lost, like in your case. The same valve can also give you fits during bleeding if you dont have the lockout tool that screws in where the sensor wire goes or if you jam on the pedal too much when bleeding.
Mike 1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop Obligatory Build Thread HERE! 1979 C20 RCLB - 350 - TH350 Auto |
05-15-2020, 03:32 PM | #7 |
On older vehicles getting everything new, they appear to appreciate the following:
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
05-15-2020, 03:38 PM | #8 |
The front brakes on my 84 k30 CUCV worked fine even when the rear MC reservoir was empty. One of the T shaped push rods had escaped a rear wheel cylinder and resulted in a leak. The brake warning light coming on was my first clue I had a problem as braking was near normal.
05-15-2020, 05:58 PM | #9 | |
05-22-2020, 06:36 PM | #10 |
Is there a way to know whether or not the rear brakes are actually working as they should? I used a brake bleeder (vacuum type) to bleed the rear brakes.
05-22-2020, 10:33 PM | #11 | |
Or, you still have a ton of air.
05-23-2020, 07:24 AM | #12 |
I didn't notice much difference on my K30. The brake light stayed off after the repairs and the MC stays full so I assume that something is working. The rears don't normally add much braking power anyway.
Did you do the trick of backing up several times and quickly stopping? That is how to get the auto-adjust to work on rear drums. |
