05-19-2020, 02:05 AM | #1 |
Back Up Camera... suggestions?
Back Up Camera - one of the accessories I want to add to my 2004 Sierra is a backup camera. I am thinking a new DIN radio with camera capabilities - Have any of you have gone this route? Thanks
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
05-22-2020, 09:03 PM | #2 |
Re: Back Up Camera... suggestions?
I haven't, but have thought of some ways to do it. Hate to get rid of my factory radio because I like it better than double dins. I believe some GPS units have back-up cam capability via bluetooth, another option if you don't want to dump your radio. Just think of the am/fm in the 72s... back then nobody thought it would be a bad idea to upgrade to a Kraco with am/fm+CASSETTE!! But - double din probably the slickest way to go for built-in approach. I added a lower end model dash cupholder to my silverado (yes, now have 4 cupholders, but it looks factory correct ) and have been toying with some idea on how to hide a GPS inside the fold-out cupholder and use it as GPS/bu cam only, when it is open. But it's a pretty tight fit, kinda gave up and decided to get 4 big gulps. But it is a starting point...
05-23-2020, 03:16 PM | #3 | |
05-23-2020, 06:29 PM | #4 |
I helped a friend put one on his 4x4 Excursion. He mounted the camera to the roof rack, and we angled it down for a more advantageous angle. For the things he did with it quite often.
The radio was a double din from Crutchfield, and the hardest part was running the wiring. Everything else was pretty easy especially using you tube as a guide. Well once installed, and running it could have lines showing your direction. They would how ever not move like my Silverado version does to show what your going to hit. All in all if you want one I would recommend you do it, but while at it I would get the best you can afford. This way you can have navigation on the radio. Which by itself is not worth it to me, but with a camera. I will get one for my Willys, and set it up like he did. |
05-23-2020, 08:36 PM | #5 | |
