05-21-2020, 10:36 PM | #1 |
1 ton wheels
I have a 1975 1 ton? that has split rims. It is the P30 chassis, so i don't know if that is any different than the 1 ton. This is not the 10 lug pattern with split rims, but the 8 lug. I read that most 8 lugs are the same minus some newer trucks. Will I be able to get generic Chevy steel wheels in the same 16" size and bolt them up?
05-23-2020, 02:28 AM | #2 |
Re: 1 ton wheels
Yes the 8 lug wheel pattern is the same. However the center hole may be slightly different. Make sure that you dont buy wheels that have a smaller center hole or you will need to break out a file or die grinder.
05-29-2020, 10:40 AM | #3 |
Re: 1 ton wheels
Are those split rims or just a lock ring?
06-01-2020, 01:26 PM | #4 |
Re: 1 ton wheels
I think they will fit up to 2010 then the bolt pattern changed - of course you’ll need to verify hub will clear also....
