05-23-2020, 07:39 PM | #1 |
Pump to Carb gas line question
1972 350 with stock fuel pump. I'd like to use an Edelbrock 81233 line, but have read it won't fit with stock pump. I'm totally ignorant about fittings. Does anyone have a part number for the adapter? Thanks
05-23-2020, 08:11 PM | #2 |
Re: Pump to Carb gas line question
Post a photo of the pump and fuel line, after almost 50 yrs it may have been changed, to a newer model. Fitting on mine, I went with 5/16 female inverted flare to 3/8 male inverted flare......3/8 was outlet side of the pump, to a 5/16 fuel line. Hope that makes sense.
05-23-2020, 08:44 PM | #3 |
Thanks. Pump is stock replacement with 3 lines. Fuel line I'm looking at has a 6 AN fitting. Suppose I could take off the line I have, go to a parts store and then try to find an adapter. I dunno.
05-23-2020, 08:57 PM | #4 |
I used this, but on a stock pump with 2 lines:
https://www.summitracing.com/search/...word=949096erl
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed Last edited by ElKotze; 05-23-2020 at 09:11 PM. |
05-24-2020, 01:41 PM | #5 |
Thank you!
05-24-2020, 09:36 PM | #6 |
Post a picture of your fuel pump. There are to many chevy fuel pump to try and guess witch one you have. How ever if you have one that has a threaded fitting at the pump you can change the fitting to a 6AN.
05-25-2020, 12:35 PM | #7 |
Okay. Here's the pump. I think I have it covered with the adapter mentioned previously, but always open to different ideas. Pic is sideways for some reason.
