'67 front disc conversion question
I need to clarify something on my conversion. I have a '67 1/2 ton and I will be using a set of spindles from a '71 C10 and they are a 6 lug set. So were the 6 lug discs on the '71/72 only on 4x4's? I need to replace my ball joints to install my new spindles and just need to know which are the correct ball joints for my new setup.
![]() Join Date: Nov 2001
Re: '67 front disc conversion question
The 6 lug disc never was factory on a Pre-86 2wd truck. They are a new aftermarket part.
But, to answer your ball joint question... the upper and lower ball joints just match the specific year spindle you ordered. Also... all your steering linkage must match the specific year spindle used as well.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
