Roto Reuter thats the name...
![]() Join Date: Feb 2010
Help with Dana-44 front axle pinion seal
So on my 70 K10, I originally thought my leaking front axle issue was coming from my cover, but it turns out to be the pinion seal. I decided to replace the seal. After removing the pinion nut and seal, I was reading that many people match-mark the nut and shaft for reinstalling. Should I have done that on my front axle nut? What is the proper procedure for replacing the front pinion seal? I've seen differing torque values, loctite the nut, Silicone on splines, etc. Can someone help me out? I want to get this back together asap.
Front Dana 44 with pinion seal removed Original pinion seal New pinion seal part number New seal looks different then original one
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
All about them K’s
![]() Join Date: Jun 2014
Re: Help with Dana-44 front axle pinion seal
I’ve put several of them back together with white Teflon paste on the threads and a torque of 150ftlbs. Never had an issue at all what so ever. I’m pretty confident the 44’s in these trucks use pinion shims so even when your setting them up for the first time you don’t need a whole lot of torque on the nut. I normally try to use a new lock nut when I replace the seal.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() Last edited by 57taskforce; 05-26-2020 at 12:12 PM. |
![]() Join Date: Mar 2003
That is actually the correct seal. The one you are replacing has been replaced before. Pre-lube the seal before installing. Get a bearing race 603049 (as a tool) and use it to put the seal in. You will see it fits in the groove of the seal perfectly, then tap it in with a ball peen hammer. Dana 44 is shimmed so nut tightens down to a about 150 pounds with a few drops of locktite if you are using it over. Put some teflon sealer on the splines also
So I see some people put some RTV on the splines. Does that help? And is it recommended?
All about them K’s
The Teflon paste does the same thing as the silicone but it never fully hardens.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Yeah, please don't use silicone. After you do, it takes pullers and a hammer to get the yoke off again if needed.
Yikes. Never thought about that.
I think there was an oil slinger behind the seal originally (E) and a foam seal to prevent oil from seeping down the splines (B). Or is B the washer?
Yes there was an oil slinger behind the seal. There was bearing, oil slinger, oil seal, yoke, washer, then nut. I did not have any type of foam seal.
I've seen them with or without the E slinger. Doesn't make any difference in set-up or the way it runs
All about them K’s
Thanks again for posting the part number. I got the seal for mine today, went in no trouble and fixed my leak. Coincidentally mine had the same leaking seal as yours, mine wasn’t the rubber lips that were leaking but rather the lower edge of the metal seal body its self(outside diameter of the seal). Mine has the slinger.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() Last edited by 57taskforce; 06-03-2020 at 10:52 PM. |
Finished up mine as well. So far so good.
