Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 05-27-2020, 08:54 PM   #1
3QTRTONS
3QTRTONS's Avatar
85 c60 cab onto a k30 cab & chassis?
Can't seem to find much info on this. I've been told (seen) where the c60 floor is flatter, etc., than a c10 pickup cab. But what about on a cab and chassis frame? Please redirect this post to the correct forum if need be, but I figure the Heavy Haulers would be the place to start. Thanks!
1969 ES5500 B E A S T 1976 K20 Suburban
1983 C10 'farm truck' 1984 K10 Suburban
1988 V30 Fire Truck
1941 Dodge WC18 Ambulance
2000 GMC Bus (parts warehouse)
3QTRTONS is offline   Reply With Quote
Old 05-27-2020, 10:50 PM   #2
Bigdually
Re: 85 c60 cab onto a k30 cab & chassis?
Aside from the noted lower flat hump in the floor, the firewall is different. Not really sure how much massaging it would take to get a one ton front clip to fit. As far as cab mounts go, I may be wrong but from a quick glance they appear they're the same as a c10-30 cab, the medium dutys use tall bushings to make up for how high they sit above the frame.
Note too that all year square medium duties have the dimmer switch on the floor and wiper switch on the dash like the pre-83 pickups and unless the truck was optioned with the big back window, you'll have the small back window. The sheet metal surrounding the window hole on the mediums is different than a pickup, so to install the bigger window is more involved than simply cutting out the stamped hole and slapping it in.
2.5 Ton Pickup Build:
1989 GMC 6000 Pickup/Toy Conversion
Bigdually is offline   Reply With Quote
Old 05-28-2020, 07:36 AM   #3
sweetk30
sweetk30's Avatar
C&C frame is the same as a pickup frame just longer for wheel base or no box on it .
so fitting the c40-up cabs to reg 1ton down frames will be a bit tricky but to a good fab person can be done .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-31-2020, 11:38 AM   #4
3QTRTONS
3QTRTONS's Avatar
Thanks for the replies! Figured it would be quite involved......
1988 V30 Fire Truck
Old 05-31-2020, 08:10 PM   #5
sweetk30
sweetk30's Avatar
whats the plan anyways ? maybe we can give you a better option to look at .
