redoing headliner ?
Just in the process of fixing the sagging headliner and starting taking off the old glue and it pulls off like paper and leaves the fiberglass type headliner. I read on anther truck forum that he sprayed the headliner after it was cleaned with a polyurethane spray and let it dry and then used glue and put on headliner in the normal fashion. Is this a good idea to spray something on the headliner to help hold the fibers and make the headliner more uniform ?
Robert Olson Transport
![]() Join Date: Oct 2002
Re: redoing headliner ?
you could spray it with an aerosol clear coat
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Just wondering if the glue and headliner would pull off the clear coat ?
#4 | |
When it comes to almost everything including adhesives, surface prep is everything. Simply carefully cleaning the scuzzy old foam worked for me, but I wouldn't be surprised to hear additional efforts may work as well.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
I just did mine no clearcoat just removed the foam from the cardboard . Used weldwood landau top high heat resistant glue sprayed on with an old binks N° 7.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
The foam just brushed off with a scrub brush . The hitch was for weight I lightly moistened the cardboard and placed weight on it to remove the sag worked out well.
Like others here, had the same problem with my 1988 Suburban, but decided to go another way.
Now, the Suburban has the old fashion "vinyl and bow" headliner with sound deadening (Dynomat) along with 3M™ Thinsulate™ Acoustic Insulation SM400L for heat/cool and sound control. Also thought the vinyl-bow was a more classic look than the fuzzy stuff. Enjoy, |
#8 | |
![]() Join Date: Oct 2014
I’ve done several headliners, and never needed to spray anything but the adhesive glue on the headliner board. All the old foam can be removed using a wire brush. Then spray about half the the board and half the headliner material. Once that half in done, move to the other half. The adhesive I use is the High Temp for high heat area, like headliners.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
#11 | |
https://www.miamicorp.com/products/H...EADLINING.aspx https://www.miamicorp.com/customer/m...Headlining.pdf
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 06-09-2020 at 08:10 AM. |
#12 | |
Perferated and snakebite
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 06-11-2020 at 08:45 AM. |
#13 | |
https://www.jjautofabrics.com/endura...-sold-by-yard/
Thanks for all the suggestions. Making headway on removing the old stuff,wear a mask, it bothered me at first. The only trouble is none of the products you mentioned are not available in Can. I had no luck with super 77 on simple projects. Might try loctite high heat adhesive
#15 | |
https://www.miamicorp.com/default.as...13&parent=2699 https://www.stockinteriors.com/headl...sp?ItemId=6731 https://www.amazon.com/High-Temp-Per.../dp/B072LYCDLH
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 06-07-2020 at 07:34 AM. |
#16 | |
#17 |
1 can for a regular cab pickup. But I like to keep an extra can on hand just in case.
#18 |
I,ve tried and comes saying no sellers available to ship to your area. Don,t know if it is the CPP virus thing or certain chemicals can,t be shipped to Can.
#19 |
Try an upholstery shop they should be able to steer you right direction to buy the glue. Or many even sell you some.
#20 |
All this talk about headliners -- Did all trucks come with a headliner?
Mine doesn't have one. It's just steel overhead. Was it removed at some point, or was it only included with the high-optioned trucks?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
#21 |
Some trucks did not come with headliners. But they can be added, you just need the interior headliner trim and headliner.
#22 | |
blazer2007:
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
#23 |
I tried some super 77 on some material on the side panels on my Blazer and it started letting go after a year. We get some real hot weather here in the Okanagan valley. I talked to a upholstery shop and she said she uses Lepages contact cement from Home depot but she doesn,t do headliners as no one wants to pay her for all that work at $85 a hour
#24 |
Thanks for the link to Miami, TKCR! I ordered white perforated, foam back headliner for the crew cab this morning.
#25 | |
