Old 12-12-2003, 02:52 AM   #1
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
Removing Fenders, tough job?
i need to remove my front fenders to repaint them. how do you do it, and is it fairly complicated?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 12-12-2003, 10:51 AM   #2
ChevyDude
I really don't think it's all that difficult. You start by removing the windshield wipers, then remove the cowl, then remove all the fender bolts and it should come right off. Be care if there are spacers under any of the bolts that you make a note how many where there and which bolt hole they were on. Put the fender back the EXACT same way and it should line up just fine. Hope that helps.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 12-12-2003, 10:55 AM   #3
Randy70C-10
Randy70C-10's Avatar
It's easier to do than explain. I can give you this advice though, it's easier to remove to entire front clip all in one piece.
Randy70C-10 is offline   Reply With Quote
Old 12-12-2003, 02:20 PM   #4
70short
Dont forget the HOOD !!!
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 12-12-2003, 03:49 PM   #5
72MARIO
72MARIO's Avatar
Um....
If you want everything to line back up once it's painted drill 1/8" holes in the hood hinge into the hood and in the fenders by the bolts into the cab. Mark where any of the body shims were removed from.
I guess it would be hard if the bolt's were sized or if you were totally Wasted.
Good Luck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-12-2003, 03:55 PM   #6
72MARIO
72MARIO's Avatar
I found some pics of the bolts. Sorry for the paint drawings. I am not a Computer Pro.
2005 TAHOE DD
Old 12-12-2003, 04:00 PM   #7
72MARIO
72MARIO's Avatar
Here
2005 TAHOE DD
