Old 06-18-2020, 03:57 PM   #1
nrb's70gmc
nrb's70gmc's Avatar
4wd Engine Crossmember In 2wd Truck?
Im looking at replacing my 2wd crossmember with a dirty dingo 4wd LS crossmember.
Ive decided to build the complete front suspension (long travel) and i want to use the 4wd dirty dingo crossmember as a starting point. the DD crossmember bolts in the 4wd frame.
does a 2wd frame have the same frame holes as a 4wd frame? will it bolt in or would i need to drill holes?
This is on a 3/4 ton frame
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
