Old 06-26-2020, 06:26 PM   #1
CCCC
CCCC's Avatar
Seals for Holley fuel transfer tube
Just rebuilt a Holley and the new kit provided some sort of boots to seal each end of the fuel tube (connecting front and back bowls) - had never seem those before - normal sealing in past has been done with "O" rings. Not good so far - they both leak.
Is there some unique trick for installing these boots so they will seal properly (I did lightly lube the tube) and what might I have done wrong? Will go digging back into the left-over seals/gaskets to see if the kit also provided "O" rings as well, and probably will install those in an effort to end the leaking.
But, if you have experience with these boot type seals and can give insight on how to succeed, I would like to know. Thanks.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 06-26-2020, 08:26 PM   #2
geezer#99
geezer#99's Avatar
Re: Seals for Holley fuel transfer tube
That boot is the new style.
Made for a tube that doesn’t have the little ridge. Just smooth pipe.
You need o rings for the ridge type tube.
I use Vaseline on the ends of the tubes and o rings to get them on and sealed.
Parts store should have o rings.
Old 06-27-2020, 05:18 PM   #3
CCCC
CCCC's Avatar
Thanks geezer - makes sense now that you gave the update.. All of the Holleys here are plenty old - no smooth pipes. I will find the needed "O" rings. Thanks again.
CCCC
Old 06-27-2020, 09:57 PM   #4
BigBird05
The O-rings need to be for the new fuel or it will eat them up in no time.
BigBird05 is offline   Reply With Quote
Old 06-28-2020, 05:39 PM   #5
CCCC
CCCC's Avatar
If you are talking about fuel with ethanol - good caution - although the big problems for me were corrosion in fuel tank and lines with resulting residue crud clogging and getting past filters, and eating fuel pump diaphragms. No "O" rings eaten yet.
But, I am no succeeding in keeping real gas (no ethanol) in the old trucks so have not been worried as in the past. Is "new gas" something else beyond the ethanol?
I have a chance to get a supply of AV gas - any problems there?
CCCC
