Old 06-27-2020, 05:42 PM   #1
Sevens
Sevens's Avatar
What chassis do I have?
I have a 1965 GMC 3/4 ton truck...that's what the VIN number tells me anyway...
At some point in its lifetime, someone did a 5 lug swap and drivetrain swap; it has leaf-springs in the rear. I believe everything that was swapped was from a 1975 C10 (based on casting numbers and the PO's story).
I plan on lowering the rear-end a few inches.
I don't want to buy parts and see if they fit only to find out that they are wrong.
My question is this; is there a difference between a 1965 chassis and a 1975 chassis...and if so, how can I tell which one mine is?
-Tim
'65 GMC that identifies as a Chevrolet
Sevens is offline   Reply With Quote
Old 06-27-2020, 05:57 PM   #2
mongocanfly
mongocanfly's Avatar
Re: What chassis do I have?
Are you asking about the frame?...I would suspect a big difference In the frames..are cab and body mounts stock looking or homemade looking?...is the rear soa or aos?...if aos ,then a simple drop block and ubolts would do it
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-27-2020, 06:01 PM   #3
Sevens
Sevens's Avatar
Yes, the frame... The mounts all look stock; but I'm not sure that is definitive.
It is soa, so I can't do blocks and U-bolts.
I've been searching for a bit and haven't been able to find any definitive way to tell them apart...I'm hoping someone on here has the answer!
-Tim
Old 06-27-2020, 06:20 PM   #4
mongocanfly
If all the body mounts look stock to the frame, then most likely they did a drivetrain swap...can you get pics of the drivetrain parts and mounts?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-27-2020, 06:54 PM   #5
Sevens
Sevens's Avatar
It looks factory to me for the most part.
More photos:
Driver side body mounts:
The bracket is riveted and looks stock...but why are there two sets of holes?
Name:  Body Mounts.jpg
Leaf-spring mount:
Rear-end:
Welded-on shock mount:
Name:  Shock Mount.jpg
-Tim
Old 06-27-2020, 07:03 PM   #6
Sevens
Sevens's Avatar
I had big plans for this truck this year but unfortunately I got laid off about 3 weeks ago. I am going to have to hit the pause button for a while on the "big" stuff.
-Tim
Old 06-27-2020, 07:37 PM   #7
cwcarpenter98
cwcarpenter98's Avatar
Most GMCs came with leaf springs in the rear from the factory. Do the front frame horns match the contour of the bumper?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 06-27-2020, 09:45 PM   #8
mongocanfly
From what I can see it looks like your on a stock frame,,, but the rear axle has been swapped...
For a quick easy/cheap drop in the rear , you could pull a couple of leaves outta the spring pack..
It will affect ride and hauling, but if those are stock 3/4t springs it may not matter much....
Drop springs would be the ideal way to do it though....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-27-2020, 10:58 PM   #9
Captainfab
60-66 Nut
That is your original frame with a 12 bolt swap likely from the '75 donor. GMC's came standard with leaf springs.
Old 06-27-2020, 11:26 PM   #10
Sevens
Sevens's Avatar
I never thought to check the bumper.... Yes, it matches the contour. I think that answers my question! Thanks Chris.
I was thinking about a shackle extension to drop 2". I think that would allow me to keep the same ride-quality.
Thank you, I appreciate the input!
You guys rock!
-Tim
Old 06-28-2020, 12:41 AM   #11
mongocanfly
How much clearance do you have between the spring eye and the bed floor? It looks fairly close in your pic..
A drop shackle may also change your pinion angle some...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-28-2020, 01:27 PM   #12
Sevens
Sevens's Avatar
I will have to measure it...but this camera angle is deceiving. There is more room than there appears from this angle.
I will probably just buy the leaf springs either way.
-Tim
Old 06-28-2020, 08:52 PM   #13
lobuck64
Hey I got 65 gmc swb used 76 rear axle used flip kit for 73-87 still using original springs replaced bushings and hangers tried to upload a picture but would not load send me a pm if you want info on bushings and hangers
lobuck64 is offline   Reply With Quote
