Old 06-27-2020, 10:50 PM   #1
tdangle
tdangle's Avatar
Bet you don't see this often
Not only appears to be original, it has something else.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 06-28-2020, 12:10 AM   #2
Astro-Balls
Astro-Balls's Avatar
Re: Bet you don't see this often
Tried removing the straight slotted screw yet?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 06-28-2020, 11:54 AM   #3
tdangle
tdangle's Avatar
Yep,
If it's tight, use an impact screwdriver. Works great!
Terry
Old 06-28-2020, 11:59 AM   #4
72c20customcamper
72c20customcamper's Avatar
Mine came out with a few taps and regular screw driver
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-29-2020, 02:58 AM   #5
toolboxchev
Originally Posted by tdangle View Post
Yep,
I install them that way also. Most of the newer drums do not have these machined into the drum.
Its there for a reason. Freakin Aftermarket!
toolboxchev is offline   Reply With Quote
Old 06-29-2020, 07:43 AM   #6
Minkota
I have worked on many of those. that slotted screw is one reason I own an Impact Driver (screwdriver you hit with a hammer and the tip turns when it is hit).
Minkota is offline   Reply With Quote
Old 06-29-2020, 10:51 AM   #7
weim55
I’ve NEVER seen a 67-72 8 lug with a slide on rear drum. My ‘50 3600 w/ HO52 is that style. Is this on your ‘70?
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 06-28-2020, 12:24 AM   #8
leddzepp
Moderator
leddzepp's Avatar
Luckily I’ve never had a problem removing the slotted screw. It’s pretty short and doesn’t have a lot of threads.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-29-2020, 03:12 PM   #9
RichardJ
I have two Dana 60's, but only the '67 has the slotted screws. The '69 does not, but it is a Roadrunner with a 5-lug, semi-floating, Dana 60. He,he.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 06-29-2020, 04:48 PM   #10
tdangle
tdangle's Avatar
and I assume 4 speed. 383 or 440?
Terry
