Old 06-30-2020, 03:43 PM   #1
ncsurveyor
Trying to figure out what steering parts I need
The more I research it the more confused I get. I've got a 68 c10. I'm doing an ls swap and doing power steering. My engine has already has a power steering pump. I've ordered a rebuilt column from a 68 from Kev's Classics. I know I need a steering box, pitman arm and rag joint. What else? Specifically what i'm trying to figure out is what all components are involved in the steering shaft area. Is there an intermediate shaft between the rag joint and the column? What about the shaft between the rag joint and the steering box, is that a seperate part?
I apologize for my confusion, trying to learn as I go.
Thanks,
Phillip
ncsurveyor is offline   Reply With Quote
Old 06-30-2020, 03:56 PM   #2
americanmusc1e
americanmusc1e's Avatar
Re: Trying to figure out what steering parts I need
I've not done that exact swap, but you'll need hoses. The LS PS pump most likely has metric fittings and the C10 box has american fittings.
Power steering trucks don't have an intermediate shaft. Just a rag joint at the bottom but the steering box is bigger and longer.
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 06-30-2020, 05:02 PM   #3
ncsurveyor
Does it look like these two would fit each other and the pump on my engine?
https://www.performanceonline.com/po...ainless-steel/
https://www.performanceonline.com/19...sion-Gear-Box/
Old 06-30-2020, 05:11 PM   #4
americanmusc1e
Both of those should work. That AN line kit is cleaner than the way that I did it. If i recall, you can take the flare fitting out of the back of an old SBC power steering pump and put it in the LS pump so you can use the C10 lines. If you don't have the original pump laying around, the AN line kit is probably easier.
That gearbox also looks right. Personally I have the quick ratio and I wish I had gone standard. Whatever you get, make sure your rag joint is the same 30 spline because there are two different splines depending on the year.
-- Josh
Old 06-30-2020, 05:19 PM   #5
ncsurveyor
I'm still confused about an intermediate steering shaft or coupler. Is that something I need?
Old 06-30-2020, 05:36 PM   #6
americanmusc1e
I just found a picture of my stock 1970 power steering shaft. I hope this helps.
-- Josh
Old 06-30-2020, 05:35 PM   #7
ncsurveyor
and does the rag joint bolt directly to the gear box input shaft?
Old 06-30-2020, 05:39 PM   #8
americanmusc1e
the rag joint should have a splined end to mate to the spline on the gearbox.
-- Josh
Old 06-30-2020, 05:48 PM   #9
gmc684x4
If the metric hose is long enough you can cut the end of use old style flare fitting and re flare to
I am putting an 88 98 pump in my truck i plan on switching the fitting on back off pumps
gmc684x4 is offline   Reply With Quote
Old 06-30-2020, 05:51 PM   #10
americanmusc1e
https://www.summitracing.com/parts/CLP-500IOA
I got a set of these to run metric lines on a 70's GM gearbox on my 49. They work as well as long as the metric lines will fit your frame.
-- Josh
Old 07-01-2020, 09:36 AM   #11
clay68c10
clay68c10's Avatar
If it’s a 68 column, it will be the same length as what you have now. It won’t need an intermediate shaft. You can get the rag joint rebuild kit if you need it.
For the steering box;
If you want to have the same hydraulic line style as your LS pump, buy one for a later square body. 82ish should work. Then an off the shelf pressure hose will go on and work fine.
If you want to go with the early style flare fitting box, just change out the pressure output on the LS pump to the early style and buy a pressure hose for that style.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is online now   Reply With Quote
Old 07-01-2020, 01:36 PM   #12
gmc684x4
Are you running the ls auto tranny as well ?
They make a 4 speeed auto indicator for 67 72 trucks now
Talking yo a few ppl on here that have done it tell me the original column works well with the new tranny
