Old 07-04-2020, 02:05 PM   #1
Lugnutz65
Lugnutz65's Avatar
Cylinder leak down test results - warm engine
Today I completed another cylinder leak down test after I got the engine up to operating temperature. I ran the engine for about eight minutes at a variety of RPMs and temperature stabilized at 190°.
Shut her down.
Plugs were removed.
Valve covers were removed.
All rockers were loosened so that all valves were simultaneously closed. Valve covers were replaced so that I could listen for air leaking through the oil fill cap, intake manifold, and exhaust systems. The PCV and fresh air intake tubing was also disconnected from the intake.
All cylinders were tested with 100 psi. VIDEO
The photo shows a chart of my results. I have blow by in cylinders #2, #5, #8. I also seem to have intake valves that are not sealing properly. I heard some air through the intake on cylinders #5, #7, #8.
Here is a result I DIDN’T EXPECT!
Cylinder #6 tested in the low 60s TWICE on prior leak down tests. It’s now at 93%.
I now have a dilemma.
1. Do I run the engine on the run stand and see if the other cylinders improve, like #6 improved? If I choose this option, I will probably swap the oil for some break in oil. Perhaps a straight 30 weight oil would be best.
2. Do I approach the engine builder with the results I have?
3. Should I remove the oil pan and look for pieces of broken rings?
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 07-04-2020, 06:47 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Cylinder leak down test results - warm engine
The higher figures on previously low cylinders is likely due to oil being pulled into the chamber sealing off the rings..
Highly unlikely you wont find broken rings in the sump....
I would contact the builder asap....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 07-05-2020, 09:07 AM   #3
GerhardH
GerhardH's Avatar
Very interesting.
Maybe you can perform additional a compression test and post?
Anyway good luck.
Best regards GerhardH!
Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20
1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400
http://67-72chevytrucks.com/vboard/s...d.php?t=760400
GerhardH is offline   Reply With Quote
Old 07-07-2020, 11:02 AM   #4
Lugnutz65
Lugnutz65's Avatar
Originally Posted by GerhardH View Post
Very interesting.
Anyway good luck.
Now that the blow by gasses have been diverted (PCV disconnected) I can do another compression test. Prior tests were essentially “wet” with oil.
I’ll post my findings.
I had a very good conversation with the builder. He seems eager to help solve the issues. This will take time but I’m learning stuff, so I’ll keep a positive attitude.
Old 07-07-2020, 03:20 PM   #5
GerhardH
GerhardH's Avatar
Yes cool!!!
Old 07-10-2020, 08:39 PM   #6
AussieinNC
Moderator
AussieinNC's Avatar
Any updates on this one?
2012 Chevy Equinox
Old 07-05-2020, 12:36 PM   #7
AussieinNC
Moderator
AussieinNC's Avatar
No need for break in oil...these are roller lifter engines and dont need the Zinc found in break in oils....
Zinc will kill a CAT if you use break in oil in a vehicle with CATS....
2012 Chevy Equinox
Old 07-26-2020, 04:42 PM   #8
jjzepplin
jjzepplin's Avatar
This is not good news at all. Good luck sir.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-27-2020, 11:17 AM   #9
GerhardH
GerhardH's Avatar
Oh good luck from my side too.
Old 09-06-2020, 07:38 AM   #10
GerhardH
GerhardH's Avatar
Just for info, have done mine:
http://67-72chevytrucks.com/vboard/s...=760400&page=4
Old 09-06-2020, 07:41 AM   #11
Lugnutz65
Lugnutz65's Avatar
Good info. Thanks.
Old 09-08-2020, 11:44 PM   #12
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Just for the next guy reading this thread, coolant temp is not necessary operating temp... temp of the oil is really operating temp.
8 minutes of running just tickled the oil temperature for a operating temp leak down test..
Its like putting frozen hamburger meat in the microwave for 5 minutes on high, yeah, outsides hot and well, yuk, inside, cold and raw.
not saying it's going to help your case, but, again for the next guy who reads on...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
