Old 07-08-2020, 02:43 AM   #1
Dr.redneck99
Steering column conversion
Greetings all, I'm relatively new to the forum, so apologies in advance.
I have a factory Granny 4 speed, 4x4 truck that I want to put a tilt column in. I happen to have the automatic tilt column out of an old Chevy R.V. that is era correct.
Is it possible to build a manual tilt column out of the 2?
Would it be smarter just to buy one after market?
Have any of you ever seen such a combination?
Dr.redneck99 is offline   Reply With Quote
Old 07-09-2020, 09:05 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Steering column conversion
Hello and welcome to the board.
Use the search feature it will pull up threads all about what you want to do. I have done one and it's not to hard to do if you take your time. It's even easier if you are some one you know can weld aluminum. The bowl is not metal! Ask me how I know, but any way not hard at all. I did this one for my ramp truck. It also has the 4 speed granny gear. I ended up using plumbs putty to fill the holes.
Here is how I did mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=760936
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-09-2020, 12:00 PM   #3
mr48chev
mr48chev's Avatar
Guys used to remove the column shift lever and cut the part of the collar that holds the lever off and fill the hole, sand it down and paint it back years ago before aftermarket columns showed up when they put floor shifts in vehicles. Those were the ones who wanted a finished look, a lot of guys just knocked the pin out, removed the lever and called it good.
The non tilt collar won't work on the tilt column though. I wouldn't tear the old column up anyhow because it is good trading material
I'm going to say that your skill and patience levels become involved when it comes to taking a tilt column apart to do something like fill that shift arm hole in the collar, You may or may not want to take it apart.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 07-17-2020, 11:49 PM   #4
Dr.redneck99
Thank you both, as for now the original column is going back in, but I will keep this in mind when I pull the tilt out to rebuild it.
Old 07-19-2020, 12:15 AM   #5
lugnut
lugnut's Avatar
I was in the same boat and was thinking of converting an auto column to a floor shift but got some good advice from members and ended up getting a floor shift tilt from Randy500. He is a member here, I'd suggest contacting him. I highly recommend staying away from the method of grinding off the old knob on your auto column and filling in with epoxy. It's your choice but I personally don't like it.
1967 Chevrolet 1/2 ton 4x4
1972 GMC 1/2 ton 4x4
2005 1500 4x4 Suburban
2004 GMC Envoy 4x4 (wife's)
lugnut is offline   Reply With Quote
