Old 07-12-2020, 01:35 PM   #1
Perpendicular
SB StepSide angle strip removal
Has anyone ever removed the angle strip from a bedside of a stepside? The truck I bought a bit ago (which is eating my lunch) has rust bubbling up behind the strips. I picked up new strips but it appears the original ones are spot welded on - many times......
I would rather not destroy the bedsides trying to grind them off :/
Any guidance would be FANTASTIC!
Perpendicular is offline   Reply With Quote
Old 07-12-2020, 05:44 PM   #2
sweetk30
sweetk30's Avatar
Re: SB StepSide angle strip removal
spot weld cutter on drill . drill each one and pop off and clean / dress / weld in new .
unless there reg welds and not just pinch / spot welds .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 07-12-2020, 06:09 PM   #3
mongocanfly
mongocanfly's Avatar
Bad thing about a spot weld bit is that itll drill thru your bedside to cut the spot weld out....
Actually grinding the welds off will do the least amount of damage...but if your gonna weld the new strips back on the paint damage or holes wont be a issue...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-12-2020, 06:19 PM   #4
sweetk30
sweetk30's Avatar
only if you go to far with he spot weld cutter bit .
been using them for years no problems . slow and steady wins the race with them .
Old 07-12-2020, 06:38 PM   #5
Boog
laying low
Boog's Avatar
Good how to info here.
https://www.stovebolt.com/ubbthreads...&Number=325959
Somewhere there is info in our 67-72 forum too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
