Old 07-19-2020, 02:40 PM   #1
Edahall
Trailer connector troubleshooting
2001 GMC Yukon. I am getting no voltage out of this right turn signal trailer connector. The rear right turn signal does work on the vehicle itself. Where do I look next?
Edahall is offline   Reply With Quote
Old 07-20-2020, 06:37 AM   #2
Re: Trailer connector troubleshooting
I would trce the trailer pigtail back to where it joins the main wiring loom for the rear lights. I think mine was right behind the license plate area on my 2002. Then inspect for damage to loom. I would imagine you might have to unwrap it and check at the solder joint. You can also check on the pigtail socket where the wire enters the socket.
Old 07-20-2020, 04:30 PM   #3
hatzie
Moderator
hatzie's Avatar
On the 1999-2014 GM light trucks there's a junction block on the LH frame rail with four Delphi Aptive Metripak GT 280 connections.
  1. From the cab,
  2. LH tail,
  3. RH tail,
  4. Trailer.
Get out your back probes and Voltmeter or test light to check for juice at the connector on the J block.
It'll look like this...
The PDF in the link below is the General Motors Light Truck Upfitters guide for the T800 trucks.
Page 79 is the J block plug placement guide.
Pages 91-94 are the J-Block plug pinouts along with connector and terminal part numbers.
https://www.gmupfitter.com/files/med...plications.pdf
It's not impossible that the J-block is bad. Don't bother with the Dorman part get a used one.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-27-2020, 12:39 PM   #4
biketopia
There's a separate fuse inside the interior fuse panel for the trailer turn signals. After verifying that works, then check the in and out of the junction block as they are know to fail or have dirty connections and broken wires.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
