07-20-2020, 12:44 PM | #1 |
transmission output flange nut / socket ?
so i need to change the seal on the back of my spicer 5 speed in my 88 gmc 7000 truck . i have measured up the nut and cant find a socket the correct outside size to NOT bind up inside the flange body area .
anyone have any helpful hints other than the old hammer & chisel method i prefer NOT to do . looks like a 2" or 2 1/16" maybe ? across the flat's .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. Last edited by sweetk30; 07-21-2020 at 08:02 AM. |
07-22-2020, 05:56 PM | #2 |
Re: transmission output flange nut / socket ?
I once had to do a similar job. Only could find a 3/4" drive socket to fit the 1 3/4" nut but the OD was slightly too big to fit down in that pocket. I had to buy a new socket and then grind down the OD just enough to fit without making it too thin so the wall would crack. Fortunately it worked. In 30 years I have never used that socket for anything else.
07-22-2020, 06:34 PM | #3 |
Grinding down a socket just seams wrong but I have done it.
07-22-2020, 06:50 PM | #4 |
yep to us tool guys its BLASPHEMY
but you got to do it to get the job done sometimes .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
