Old 07-23-2020, 06:47 PM   #1
cruisinthe34
cruisinthe34's Avatar
Gas Tank relocation
I'm considering relocating the gas tank in my 71 SWB Stepper. Is there a complete 'KIT' out there other than LMC for this project ? I have the bed off and am redoing the wood etc, and figure now is the time to do that. Any replies are appreciated.
Steve
My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory
1971 C10 Inline 6 250 700R4 "Marlene"
1934 Chevrolet Master Sedan 350 700R4 "Iris"
1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose"
2019 Honda Ridgeline
cruisinthe34 is offline   Reply With Quote
Old 07-24-2020, 10:47 PM   #2
Peanut74
Re: Gas Tank relocation
I got mine from Brothers and also order the fuel kit at the same time. Cost wasn't bad and had everything I need to install it
Peanut74 is offline   Reply With Quote
Old 07-25-2020, 09:54 AM   #3
Zeroman
Zeroman's Avatar
As far as I know there is no "complete" kit available that includes everything you need.
Yes, the tanks from LMC, Classic Industries, etc comes with the tank, the fuel sender, the mounting straps, but nothing else. No extra fuel line, no fuel filler nozzle, no extra sender wire.
These installs are all a little different.
Step side, fleetside, wood bed, metal bed, short bed, long bed. Top fill through the bed, side bed through the bedside/fender, filler located in side marker or tail light.
Search this forum for a ton of threads on different installations. Every install is just a bit unique as are the trucks.
http://67-72chevytrucks.com/vboard/s...d.php?t=771325
FYI - The Permacap website in this thread is no longer valid. Not sure they are still available.
Zeroman is offline   Reply With Quote
Old 07-25-2020, 09:46 PM   #4
57larry
no kit but you can use a 69 camaro tank, do a search, it's a good fit
57larry is offline   Reply With Quote
Old 07-25-2020, 10:13 PM   #5
FRCvette
I did the same as peanut 74. Was not a bad install.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 07-26-2020, 09:05 PM   #6
Vero67
I did the LMC tank. I used a 71 Blazer fill tube, donor patch panel, including the cover in the bed. Looks factory, and fills without stopping.
Vero67 is offline   Reply With Quote
Old 07-27-2020, 07:42 AM   #7
Richard2112
Richard2112's Avatar
! used a 32 gal Blazer tank on my 70 C-30, built the forward support from C-channel, and relocated the filler neck.
Richard2112 is offline   Reply With Quote
Old 07-27-2020, 10:15 AM   #8
CarlsLQ9SS
CarlsLQ9SS's Avatar
I used a 1990 jeep wrangler tank and a fuel sending unit for a 1990 s10 blazer. It worked pretty good.
CarlsLQ9SS is offline   Reply With Quote
Old 07-28-2020, 08:52 AM   #9
GWWhite
I got the LMC Kit but modified it in many ways.
GWWhite is offline   Reply With Quote
Old 10-21-2020, 06:10 PM   #10
peegeez
I'm relocating my tank in my 1972 K2500.
What did you guys do with the now free space behind the seat?
peegeez is offline   Reply With Quote
Old 10-21-2020, 07:21 PM   #11
gmc684x4
subs fill that space plus what first aid kit and fire extinguisher
gmc684x4 is offline   Reply With Quote
Old 10-21-2020, 08:29 PM   #12
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Gas Tank relocation
No Limit gas tank with baffeles and sump for fuel injection if you decided to go with it later. I used it as a regular tank though. Rob is a supporting member here also.(Carolina truck shop) is who I ordered it through. I got the filler neck from a 90 model Chevy truck with the metal piece for the body also for less than $50.00 at the local LKQ yard.
https://nolimit.net/
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-21-2020, 10:05 PM   #13
atm70chevy
atm70chevy's Avatar
I used a Boyd’s Welding tank. Super nice tank and it came with the sending unit installed and mounting hardware. I’m really pleased with it and would highly recommend them.
Anthony
atm70chevy is offline   Reply With Quote
Old 10-22-2020, 09:23 AM   #14
custom10nut
custom10nut's Avatar
This is what I had planned for my truck, but then decided to keep the in cab tank, for now.
I collected everything needed, except For ordering the “Tank Kit”.
It’ll be a hard choice for me to do this conversion, as I’d like to keep the truck close to factory.
I never know though, maybe next year I’ll decide to convert it.
custom10nut is offline   Reply With Quote
Old 10-22-2020, 10:46 AM   #15
Andy4639
Old member
Andy4639's Avatar
Talking Re: Gas Tank relocation
No limit tank sits nice under the frame and you can barely see it under the back. That was why I picked it. I didn't want that big old looking drum under the truck like the other's. It came with everything I needed other than the hard lines. I moded the rear frame brace so the tank would slide inside the frame rail and give it more support and protection in case of a rer end hit. I then bolted the rear cross member back into it.
Old 10-22-2020, 05:25 PM   #16
rockyrivermark
Performance online has tanks and all necessary parts for our trucks. I put one on my ‘70 fleet side and got the tank, mounting hardware and sender
It’s a baffled aluminum tank angled in the back so it doesn’t hang down like the ugly bubble LMC blazer tanks.
Really nice set up and reasonably priced. I hear the Boyd tanks are also really nice.
https://www.performanceonline.com/19...ank-19-gallon/
RRM
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 10-22-2020, 08:11 AM   #17
3767
No 1 stop complete kit that I know of but...the Boyd tank is what I have and it’s a nice piece. You can get them thru mcb parts who are a supporting member here. U can use hot rod fuel hose for the lines. They support here as well. If this is more money than u want to put into it then look at the Holley site. They have released a line of products aimed at these trucks. Mcb is a direct supplier for them and they usually have better pricing than most on the Holley line. Good luck on your project and let us know how it turns out for u.
3767 is offline   Reply With Quote
