Old 07-26-2020, 01:52 PM   #1
bigunde
Rusty Rockerfeller
Reversed battery now now power
A buddy was helping me work on my 85 K10 and hooked the battery up backwards. I heard a pop and seen smoke in the area in the picture. No power at all now. Please help!!
bigunde is offline   Reply With Quote
Old 07-26-2020, 01:58 PM   #2
67swb72klb
67swb72klb's Avatar
Re: Reversed battery now now power
Check the block on the firewall.
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 07-26-2020, 02:00 PM   #3
bigunde
Rusty Rockerfeller
Is that a type of fusible link?
Old 07-26-2020, 02:04 PM   #4
67swb72klb
67swb72klb's Avatar
There should be.
Old 07-27-2020, 10:02 AM   #5
blazer2007
happened to me too, was the little junction block on firewall as mentioned
blazer2007 is offline   Reply With Quote
Old 07-27-2020, 11:10 AM   #6
Dead Parrot
The junction block itself isn't a fusible link. But one or more of the wires connected there have them. Also, fusible links can blow and still have most of the insulation intact.
A OEM fusible link normally is butt connected to the wire inside a hard plastic cylinder that is about 3/8"x1".
Dead Parrot is offline   Reply With Quote
Old 07-27-2020, 12:50 PM   #7
bigunde
Rusty Rockerfeller
Is that a fusible link where the two wires going into one right before the junction block? If so what size link would i need?
Old 07-27-2020, 03:55 PM   #8
Dead Parrot
Can't tell for sure. The pic pixelates too much on zoom in. My 75 has a single wire in that spot with a link and a 2nd single wire without. Don't know if OEM wire sets ever ran dual wires bound to one link. Could be a PO combined both wires on one link.
Old 07-28-2020, 06:28 PM   #9
Pontiac1976
Pontiac1976's Avatar
Yes should be down a 6-8" on the first, then the other is down by the starter. The have black plastic joined in the middle of the wire at that point and that the {fusible link} so this is How GM did it if your wire lead is say is 14GAUGE the fusible link will be at the plastic 16GAUGE so it melts there but not the rest of the wire.
( But the Factory Gauge Fusible Links seem to be a little bit thicker then the After market replacements.)
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
