07-29-2020, 10:16 AM | #1 |
1979 Dana 44 Front Axle Brake Rotor Upgrade
I'm looking to see who has done the 2 piece 4x4 hub and rotor upgrade.
I've got a Dana 44 Front Axle going into my 1969 4x4 frame, and would like to go with the 2 piece Hub, rotor combo. Parts Geek numbers. Hub Assembly 3405-05915387 Rotor 3405-07724999 |
07-29-2020, 10:31 AM | #2 |
Re: 1979 Dana 44 Front Axle Brake Rotor Upgrade
They're all two-piece hub/rotors. The wheel studs are what holds the rotor onto the back of the hub. If you press out the studs the rotor will come off the back of the hub.
What axle are you replacing? What axle is going to be installed? Does it already have disc brakes or is it drums? Open or closed knuckle? AFAIK Dana 44's were not offered in 1979 and had been replaced with the GM 10-bolt axle. Some pictures will help too.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
07-29-2020, 12:04 PM | #3 |
He has a 69 if original most likely to be a closed knuckle dana 44 with 3.73 gears
I have had a couple of 70 trucks with open knuckle dana 44 with drums I would say you also have the sm420 with rockwell tcase in your truck they have shorter front drive shaft and longer rear shaft then the sm465 with np205 tcase And yes hub and rotors are two peice on a 4x4 not one peice like c10 trucks I think it was 81 when they switched front diffs https://torqueking.com/category/1973...44-front-axle/ You will need the tierod setup for the newer diff The drag link is also longer on the open knuckle dana 44 compared to the closed knuckle It will turn a bit more sharper too If your donor truck still has its 12 bolt rear you might want to snag it as well it will be wider then the 69 diff and be closer to the same width as the front diff Last edited by gmc684x4; 07-29-2020 at 12:09 PM. |
07-30-2020, 09:57 AM | #4 |
Just swap out a complete with disc brake----either wise you will end up with a morphidite front axle to make it work correctly. Plenty of 44s and 10 bolts, just match the gear ratio to make it easier
07-30-2020, 10:53 AM | #5 | |
j
White K20 |
07-30-2020, 12:09 PM | #6 |
I'm in on the consensus
Just did this swap on my 67 K20 Used a D44 from a 76 Bolted rite up no issues and love the tighter turning radius And disk brakes |
