4 and 1/2 quart oil change?
Changed the oil in my burban yesterday . All went well till I checked the level it was overfilled. I've always used 5 quarts in 350 ci engines. Sure enough I look at the capacities in the owners manual say 8 pints in pan 2 pints for a pf35 filter. So I pulled the filter and drained it level is about right now.
And when did they start with the pint crap?
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Re: 4 and 1/2 quart oil change?
8 pints = 4 quarts. 2 pints = 1 quart. Still 5 quarts total. Some SBC engines specified a 1/2 quart filter for some reason. I had a 68 Impala w/327 that did that. Seemed to be a passenger car thing. Switched to the 1 quart version as the 1 pint version was a PITA to get out. The longer filter was still shorter then the pan so anything likely to smack the filter would be well into smashing the pan first. IIRC - the old Fram numbers were PH13 = 1 qt, PH30 = 1/2 qt. I think the current Fram number is PH5 for the 1qt version.
![]() Join Date: Mar 2003
Are you allowed to mention Fram filters on this site?? Thought they were the debil
I've only known 5 quarts. I'd be more suspicious of the dipstick being correct.
Do you see any scratch lines in it above the factory full mark? If so, probably at or close to the 5 quart point. Ford (yes, I mean blue oval) had a tsb out in the early 90's for late 80's dipsticks that where stamped wrong. Basically said drain, new filter, fill with 5 quarts and take a hacksaw blade to mark the proper full level. |
#5 | |
![]() Join Date: Feb 2000
You can still get PF35L filters- I get mine off Amazon, they're a little pricey but it only gets changed once a year on mine. The PF1218- which replaced the PF35 is not a full quart capacity
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
