Old 08-20-2020, 08:09 AM   #1
K20-Bowtie
Deadhead fuel pressure regulator
I need some guidance. I have a 72 K-20 with a 350 small block, 1406 Edelbrock carburetor and the stock mechanical fuel pump. The engine is running a little rough at idle and the exhaust smells rich. I tested the fuel pressure and it bounces from 8-9 psi (seems high for a mechanical fuel pump).
I searched the site for guidance on a deadhead fuel pressure regulator and there seems to be conflicting information. Some say a deadhead pressure regulator will damage the mechanical fuel pump.
What’s the best option for a regulator or should I go in a different direction?
K20-Bowtie is offline   Reply With Quote
Old 08-20-2020, 10:29 AM   #2
68 P.O.S.
Re: Deadhead fuel pressure regulator
Yikes, 8-9psi is too hi for an Edelbrock carb. They need no more than 6psi, or else they start to flood. I can't help on the regulator, I went with an Edelbrock fuel pump to solve that problem.
I see you're a new member, welcome aboard!
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-20-2020, 07:21 PM   #3
K20-Bowtie
Thanks - decided to replace with an Edelbrock pump.
