09-06-2020, 01:44 PM | #1 |
1988 K30 TBI, 454 left me stranded at the gas pump this morn. Filled it up,no start
Got it towed to the shop with my AMAC tow service. Poured gas down the throat and it fired right up till it burned the gas. Fuel pump? Are there any fuses that would cause a no fuel issue? Not excited about dropping a tank full of fuel.
The Hero Truck |
09-06-2020, 02:52 PM | #2 |
Re: 1988 K30 TBI, 454 left me stranded at the gas pump this morn. Filled it up,no sta
I could hear my c30 pump running but no fuel at the tbi. Turns out it had a rotten fuel line between the pump and sender. It just pumped gas inside the tank.
09-07-2020, 11:54 PM | #3 |
09-06-2020, 03:17 PM | #4 |
Is 88 the first year for pump in the tank on GM pickups ? In the 90's I did change out a in tank pump in a car and when it would not start I took it back out and back to the store thinking it was bad and then found out there was a reset button in the trunk.
09-06-2020, 04:12 PM | #5 |
Switching valve? smack the bottom of the tank you are using just about the same time somebody else turns the key on
09-06-2020, 05:44 PM | #6 |
09-06-2020, 06:33 PM | #7 |
fyi long rubber hose down the filler and suck the 20 gal of gas out . no anti suck ball inside . i do it now and then on my truck for lawn mower gas if i happen to run out .
if me and the truck is clean and you have a safe way pop the bed off . makes it better to get at them super short flex hoses from the sender to the hard lines on the frame .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-07-2020, 11:52 PM | #8 | |
This is what I’ll be doing...November maybe
09-06-2020, 07:55 PM | #9 |
some times if you tap on the bottom of the fuel tank it will start and run i have done that a few times before and it will work just enough time to get you home
09-06-2020, 08:42 PM | #10 |
Had that happen to my 87 burban . Ran to the pump filled up started and died. Had it towed to my place . Ended up dropping the tank, not fun with 40 gallons of fuel in it.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
09-06-2020, 09:55 PM | #11 |
Any chance something bumped the tank switch while entering/exiting the truck during the last fillup? Since you normally run off the same tank, it wouldn't be a normal 'check item'.
09-07-2020, 11:48 PM | #12 |
Easy to do and I wish it was that
Probably end up lifting the bed and doing both tanks...no time soon |
09-06-2020, 11:24 PM | #13 |
Here is the TBI troubleshooting charts from the service manual
09-07-2020, 12:06 AM | #14 |
09-07-2020, 11:56 AM | #15 |
Verify the pump for the tank is working. If not coming on, check the relay under the hood. If good there, check the tank routing switch.
If you can hear the pump run, my money is the pick-up hose burst. The pick-up hoses on the older pumps deteriorate from the ethanol in the fuel. The pump tries to pull the fuel up (to push it forward/out) but the hose has a breach that doesn't allow it to move beyond that point. I had the above scenario happen to both of my original pumps on the 7.4TBI in my 89 Dually. I found it using the same guide '44th Miss Inf' provided above.
09-07-2020, 11:50 PM | #16 | |
Thanks, good stuff.
11-12-2020, 09:21 AM | #17 |
11-10-2020, 11:51 AM | #18 |
Nice looking truck!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
11-11-2020, 10:19 PM | #19 |
Nice truck, reg cab duallies are great. Looks like you're on your way to solving the problem, I just wanted to comment that your truck is a V-30. From '87-'91 the squares switched to R/V, C/K went to the GMT-400 platform out in 1988. Wanted to mention it incase you need to buy parts for this problem shopping for a K30 will get your parts for the next generation of truck.
This thread is also full of great info, if you have dual fuel tanks: http://67-72chevytrucks.com/vboard/s...d.php?t=754061
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 Last edited by 83GMCK2500; 11-11-2020 at 10:29 PM. |
