Old 09-09-2020, 04:25 PM   #1
Aruba1
Leaf Springs for C30 with Dana 70HD
I currently have a 1972 C20 upgraded to C30 with an LS engine and an NV4500 transmission. All corners have been updates with hubs, brakes and differential of a 1989 or 1998 C3500 pickup. The current leaf springs is a 4 plus 1 spring and it's too soft the empty steel bed. I need something stronger.
I plan to do some heavy towing. Will the DAYTON 22419HD (4100 lb) be an overkill or should I opt for the DAYTON 22419 (3390 lb)? Is the weighted rate per side or for both sides together? I already have 5000 lb air bags but I can't rely just on the air bags to carry all that weight.
Thanks!!
Aruba1 is offline   Reply With Quote
Old 09-10-2020, 09:07 AM   #2
tjc
tjc's Avatar
Re: Leaf Springs for C30 with Dana 70HD
I just bought new leaf springs and they were labeled 3000 lbs per pair
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
tjc is offline   Reply With Quote
Old 09-10-2020, 11:10 AM   #3
Aruba1
Thanks Tom. What do you think of the before and after? Do you have a stock bed or flatbed? How many leaf was your stock setup and how many is on the new setup?
Old 09-10-2020, 12:00 PM   #4
kwmech
you'll still have (theoretically) a 3/4 ton with heavy axles. In the long run, the frame, still can only handle so much. 1 ton frames are massive.
