tailgate hinge lengths & size
So are tailgate hinges off later 70s square trucks the same as on '72s?
If have a set already off a '78 or such & it looks to be the same but wasn't for sure if I should use or not for whatever reason.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
Re: tailgate hinge lengths & size
Nobody???
laying low
![]() Join Date: Mar 2001
I don't know the answer but if you look at LMC catalog for 67-72 and 73-87 trucks and look for tailgate trunions you can find out if they have the same part numbers. And stepside or fleetside tailgates may make a difference.
I used one off a squarebody as it allowed a way for me to remove the tailgate without having to remove the trunion bolts. Had to modify the tailgate slightly to make it work.
I like the idea of square body trunions & ability to remove tailgate easier.
But I was actually talking about the length of these... Square body ones are about an inch shorter & will not let tailgate lay flat when open.
