Old 09-29-2020, 01:02 PM   #1
03BlkZ
LED instrument lights
Has anyone had any luck converting the instrument cluster lights to LED? I have been looking but I don't know what is compatible for our harness. Help please. My truck is a 70.
03BlkZ is offline   Reply With Quote
Old 09-29-2020, 01:33 PM   #2
dagnabbitt
dagnabbitt's Avatar
Re: LED instrument lights
I bought these lights, work pretty good.
https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 09-29-2020, 02:31 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: LED instrument lights
I have done 3 dashes with these LED bulbs and they work great.
https://www.youtube.com/watch?v=vRZLojkRjNw
https://www.youtube.com/watch?v=DPXrJSpJq5U
ENDPAGE 194 LED Bulbs Canbus Error Free 6000K Xenon White Super Bright 2835 Chipsets 168 2825 175 T10 W5W LED Replacement Bulbs for Car Dome Map Door Courtesy License Plate Lights(Pack of 10)
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-29-2020, 07:20 PM   #4
70cst
70cst's Avatar
Thanks for the info
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-30-2020, 11:08 AM   #5
03BlkZ
Awesome! I'll give these a try. Thanks!
Old 10-03-2020, 05:43 AM   #6
AllGoNoShow
Those look great. I'm confused tho-where did you buy those exact ones?
Disregard- I found them on amazon. Are these a plug and play replacement? Any other mods needed?
AllGoNoShow is offline   Reply With Quote
Old 10-03-2020, 10:10 AM   #7
Andy4639
Old member
Andy4639's Avatar
N0 mods just take the old bulbs out of the black socket and install.
Old 10-03-2020, 12:23 PM   #8
Southcity
Southcity's Avatar
LED dash lights are a nice upgrade, I've done it on a few trucks. But you will also want to consider that your original dimmer switch will no longer work with this upgrade. LED's require very little power, they will operate at the same brightness over a wide range of voltages. If you want to be able to dim your LED dash lights you will need to use a PWM (Pulse Wave Modulation) type dimmer.
One example:
https://www.amazon.com/Auto-Meter-91...ews/B000N8GIYG
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 04-08-2021, 05:13 PM   #9
jimijam00
Here is the link to the bulbs the guy below used. https://www.amazon.com/ENDPAGE-Chips.../dp/B07T6LQVYQ
Figured someone could use it after they spent all that time looking at youtube videos.
jimijam00 is offline   Reply With Quote
Old 10-03-2020, 04:17 PM   #10
REDROCKER652002
We upgraded my son's 69 to led. Simple, just unplug the old and plug in the new. No wiring needed and they are a lot brighter.
REDROCKER652002 is offline   Reply With Quote
Old 10-03-2020, 07:20 PM   #11
Andy4639
Old member
Andy4639's Avatar
These LED lights do dim but not much no where near the normal bulbs but they do dim.
