I'm trying....
![]() Join Date: Oct 2013
Frigidaire AC compressor decals (Limited Time Availability)
A group of us have been working to reproduce accurately the Frigidaire decals that came on the AC compressors from the factory. It is difficult because they were stamped from Frigidaire with the build date and shift. So each decal will have to be individualized.
You can read about the project here: https://67-72chevytrucks.com/vboard/...01#post8815601 Decals will cost $30 shipped. They are high quality foil decals and replicate the originals very well. To order you'll need your Code Number (which is the build date/shift). A photo of the original is appreciated. I will stop taking orders on October 7th. EDIT: Yes Dwayne I apparently can't use a calendar...but in my defense, space and time feel warped right now.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 10-01-2020 at 09:29 AM. |
I'm trying....
Re: Frigidaire AC compressor decals (Limited Time Availability)
As reference...here's the original decal and our reproduction for the '69 K10.
The Code No 100381 breaks down to MMDDYS, or rather 10 October 03 3rd 8 1968 1 First Shift
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
I'm trying....
Here are original versions of the '70-71 decal (Long 717) and '72 (Short 717). As far as I know all the '69s were 133s. But I'm sure there was probably overlap. So it's best that you specify which one of the three decals you need. If you don't have an original decal, of course you can select a build date/Code no.
#4 | |
![]() Join Date: May 2011
If still available I would like one.
Carpe manana
![]() ![]() Join Date: Dec 2010
I’ll take two each with the following codes (total 4):
1) 012521 - Jan 25, 1972 shift one 2) 030921 - March 9, 1972 shift one Thanks!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#7 | |
I'm trying....
![]() These are print to order...so posting in this thread gets you on the list. I just need your code number (build date/shift). You got it.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 10-01-2020 at 09:30 AM. |
I'm trying....
I will PM everyone payment info once we've got our complete participant list at week's end. I have ballparked the cost with the printer based on the expected number of decals run. If we have enough participants to drop the price, we're gonna. The aim is to just cover the cost.
How do you find out the built date for a 1971 chevy blazer?
#10 | |
Carpe manana
A build date code for the motor, an axle, tcase, transmission, seat foam, printed cluster circuit etc should suffice if original to the truck.
#11 | |
I'm trying....
Pete's suggestion makes the most sense to me. Find one of the dates he listed and use it for your decal. Any of those dates obviously precede the build date of the truck and logically "could be" the build date of your compressor as well.
![]() Join Date: May 2010
Still time to get two like this?
Jim |
![]() ![]() ![]() Join Date: Oct 2015
If I can still order a decal, I want:
A long 717 decal with the code 030411 (March 04,1971 shift 1) Thanks, Tim
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
I'm trying....
Absolutely Jim. All three versions are available and I'm taking orders until September 7th. EDIT: (And thanks for the pic)
Will do Tim. Got you down.
#15 |
![]() Join Date: Aug 2020
Long, 051721
#16 |
I'm trying....
#17 |
![]() Join Date: Mar 2012
Short 717
April 12, 1972 041221 I would like to get two decals. Thanks |
#18 |
I'm trying....
Got you down.
#19 |
![]() ![]() Join Date: Jan 2002
When do you want paid.
![]() ![]() 1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
#20 |
I would like to get two of the Short 717 decals, both with date code 090713.
Thank you.
Craigslist HP = torque * rpm / 5252 * pi |
#21 |
I'm trying....
I will PM everyone on Thursday. I'm going to wait until we've got our full list.
I've got you down. Third shift...I like it.
#22 |
![]() ![]() Join Date: Feb 2009
October 7 and I just made the cut
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#23 |
I'm trying....
Yep...I got ya Tony 091601
#24 |
Photo to go with my above order.
#25 |
How do you read that BTW? Sept. 16 and say what? Perhaps the unit was replaced being the truck was built May 71. If it was, can I change my order
![]() ![]() ![]() I know you wished it a happy 50th birthday in September ![]()
