Just like to part out trucks!!
Class of 69 Pics for you!!!
hi
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
he
7
11
Do you know if it'd run when put together as is?
just wonderin'
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
12
![]() Join Date: Feb 2003
decode
Canb anyone decode the number in pic # 12 ?...vehicle type etc. We already know that it's a 396 or 427, oval port, closed chamber BB......Thanks.....Zoomy
Currently Blazerless
1966 Chevelle 396, cast april 25 at the Tonawanda plant
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 12-16-2003 at 11:08 PM. |
chevelle motors were good motors!
70 longbed 496/th400/Ford 9" |
thanks
thanks BLAZERMAN.
The block is listed as either 2 or 4 bolt main. With the oval heads, I'd bet it is a 2 bolt. It sure is clean inside. It would probably be a nice one to go through Zoomy.
69 GMC K10 ..some restoration required....still.. ![]() |
Green club
I run those 702's on the 427 in the Chevelle. Closed chamber, 98cc, 2.06/1.72 valves. Mine are not stock (2.18/1.88 valves, port/bowl work), but they run great on the engine
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
#13 | ||
so the numbers TO425EF6 F13388 tells where the engine was built from originally? and what type of truck it came from? Cause my motor is a 350 but came from s new model and I am nto sure exactly what yr it came from. my grandpa's brother died before he could tell anyone what yr it came outta.
Rich
396
If it was a 427 I would've snapped it up, but IMO a strong 350 is pretty close to a 396 if you take into account the weight penalty. If I'm going with a big block weight penalty I want enough extrea cubes to make up for it. Randy has several 454's there. If he has a clean one, I'll buy it. My guess is that 396 was recently gone thru being that clean. That impressed me too. If it has a grunch of miles on it, then somebody took meticulous care of it on the inside at least......ZZ
