![]() Join Date: Aug 2015
Can this bent 4x4 cross member be straitened?
I am replacing all the rubber drive train mounts on my K10 and I am wondering if my bent rear cross member can be straitened? For example would someone with a acetylene torch and a press be able to heat it enough and make it look better? Any suggestions appreciated.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke Lariat 2007 BMW X3 2023 BMW X3 M-Sport 2020 BMW 540xi M-Sport 1995 Harley FLSTC |
Re: Can this bent 4x4 cross member be straitened?
In my humble opinion for the amount of effort that would take I bet you could get 1 pretty reasonable from 1 of the board vendors used?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
![]() Join Date: May 2017
To answer,yes almost anything metal can be straightened with enough heat ..force..and time
But have to second Thealien finding a replacement may be the better route |
All about them K’s
![]() Join Date: Jun 2014
My K20 had a similar bend in it when I bought it. It ended up that the cross member being bent was actually twisting the top of the driver side frame rail out quite a bit. I would replace it if Its possible.
http://67-72chevytrucks.com/vboard/s...=662879&page=5 See post 104 here
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Thank you all for the responses. It is pretty thick, but I wanted to check first. With your info I've already looked around and see they can be purchased for a reasonable price. I will work on obtaining one.
Changing rubber mounts has just morphed in replacing the cross member....but it will look great when done. Thanks,
I would look for a new one if it was my truck
I would also pull it out check the straitness of it with a straight edge it looks straight on the channel part of the crossmember and if fairly decent heat it up fix the bent lip and use it until i found a cleaner crossmember |
![]() Join Date: May 2003
Steve,
It looks like you have a T221 t/c you will need a cross member for that t/c. The np205 cross member is 1" taller. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#8 | |
![]() Join Date: Nov 2014
I'd straighten it. It's not that bad. Add some heat and a large cresent wrench to bend it back into shape.
Steve,
I believe I have one out in my shed. I'll check after work and let you know. Gary
I'd be interested in that Gary. No shipping on a large part would be good.
