Old 10-07-2020, 02:19 PM   #1
ChevyGearHeads
Timing
Hello Everyone!
I have a crate LM1 350 with a Crane .500/.500 cam, Summit 15123 heads and an Edelbrock Torker with a Edelbrok 1405. Distributor is a DUI with a stock vacuum advance.
Wondering where to set the timing?
Any ideas very much appreciated.
Paul
'68 C10 327/TH350
LWB
ChevyGearHeads is offline   Reply With Quote
Old 10-07-2020, 03:11 PM   #2
geezer#99
geezer#99's Avatar
Re: Timing
That’s a lot of cam for low compression.
Read this.
https://www.badasscars.com/index.cfm...&product_id=76
Old 10-07-2020, 06:13 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Re: Timing
12 degrees BTDC at idle
All in 36 degrees BTDC at 3500 rpm
That is a lot of cam for what is essentially a 9:1 compression motor...the heads you put on are 72 cc against 75 cc factory...not really enough to make a difference...
What is this engine going into?
Transmission?
Rear gear?
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 10-09-2020, 12:10 AM   #4
Ziegelsteinfaust
Re: Timing
20 some years ago CarCraft magazine did a couple of articles called agent 87.
Well they took a low compression sbc, and put the manifold vacuum to the vacuum advance on the distributor. This kept the engine easy to start, but put a good bit of power down under the curve. Compared to a normally set up combo.
I have done it a couple of times on vehicles I got with good running stock engines. The engine will have a tendency to surge in gear, but the extra torque is nice.
For low compression engines I like about 14-16* initial timing, and about 36* all in. A simple weight kit for 10 bucks works wonders.
Ziegelsteinfaust is offline   Reply With Quote
Old 10-09-2020, 09:46 AM   #5
geezer#99
geezer#99's Avatar
Re: Timing
Good to excellent timing numbers!
To control the surge just limit the vac advance amount to 10-12 degrees.
Old 10-10-2020, 12:43 PM   #6
68 P.O.S.
Re: Timing
GM engineers found years ago SBCs run best at ~36 btdc total timing. Total timing is more important to set than initial. Set your total to 36 and then check where your inital lands for reference. Also, follow the directions from DUI to setup your distributor correctly.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 10-10-2020, 03:43 PM   #7
Ziegelsteinfaust
Re: Timing
Forgot sometimes you have to increase total timing increase.
Alot of distributors have 18* total advance, but they are easy to increase to 20-22*.
distributor, engine, motor, timing, timing adjustment
