10-11-2020, 07:32 PM | #1 |
Deluxe heater control assembly into the non deluxe dash question
Now that I am going to have the Vintage Air Sure Fit the assemly Im restoring looks like I need to bend the screw mount tabs and find the right screws and j clips to mount things up. Anyone able to tell me how they manage this? The install manual shows a jnut at the top of the assembly?
10-11-2020, 08:37 PM | #2 |
Moderator
Re: Deluxe heater control assembly into the non deluxe dash question
As I recall Vintage Air has instructions.
10-11-2020, 08:49 PM | #3 |
You need 2 #6 screws and U nuts bend the tabs so they are parallel with deluxe controls. The controls have a bracket that bolts to bottom side of the dash
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
10-11-2020, 11:13 PM | #4 |
It looked like the tabs should be bent, is there a trick to doing it to not have them misalign or wreck the dash? I was going to use vise grips and just clamp close to the dash and bend away. Ill look for the #6 u nuts and screws thanks!
10-13-2020, 09:47 AM | #5 |
Active Member
Put some masking tape on the tabs and then use vise grips to bend them. Clamp the vise grips on about as far as you can.
10-13-2020, 07:41 PM | #6 |
Ive bent the tabs and tried the j clips and they end up shimming the unit down causing the unit no to fit so I just rested them on top and thread the screw through and got that worked out.
