Old 10-17-2020, 11:08 PM   #1
1G1YY
62 T700 install query
Could someone please let me know the distance between the top of the T700 trans and the low hump trans cover?
I need to work out floor shifter mounting.
1G1YY is offline   Reply With Quote
Old 10-18-2020, 01:43 PM   #2
61K10
61K10's Avatar
Re: 62 T700 install query
what is a t700? same as a us 700r post a pic
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-18-2020, 07:20 PM   #3
1G1YY
Yes, it is a T700R4 removed from a C4 Vette.
Old 10-23-2020, 09:37 PM   #4
MT65
I don’t think that dimension will be established until your transmission xmember is in and pinion angle established, lot of variables between motor mounts and transmission mounts to pick that out before they are established.....
MT65 is offline   Reply With Quote
Old 10-24-2020, 02:26 AM   #5
1G1YY
I have the driveline all set with eng and trans mounts done incl pinion angle.
The cab is still off the chassis and I was looking at preparing mounts for the shifter.
Probably best I wait until cab is mounted..thank you for your interest.
Old 10-24-2020, 05:03 AM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
I would.
I set up a 200R4 with a low hump, no problems.
Old 10-24-2020, 10:07 PM   #7
1G1YY
Thanks for your input. Gratifying to know you had no shifter install clearance issues.
Just saw your build...looks first class.
Your attention to detail sure seems to be paying off....very nice.
