Old 10-18-2020, 09:21 PM   #1
dokelle
camber
66 short bed with 72 crossmember can't get enough camber, got any suggestions
dokelle is offline   Reply With Quote
Old 10-18-2020, 09:47 PM   #2
SkinnyG
SkinnyG's Avatar
Re: camber
Remove shims?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 10-21-2020, 10:30 PM   #3
SCOTI
SCOTI's Avatar
Re: camber
What number are you trying to achieve?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-22-2020, 08:26 AM   #4
nsb29
nsb29's Avatar
Re: camber
Are you trying to get more positive or negative camber
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 10-22-2020, 08:55 AM   #5
dokelle
Re: camber
less
Old 10-22-2020, 09:25 AM   #6
geezer#99
geezer#99's Avatar
Re: camber
You can have less positive or negative!
Which is it?
Positive or negative?
geezer#99 is online now   Reply With Quote
Old 10-22-2020, 05:17 PM   #7
nsb29
nsb29's Avatar
Re: camber
Do you have the truck complete is all the weight on the truck such as motors fenders Hood etc and are you using stock springs
Old 10-22-2020, 11:24 PM   #8
dokelle
Re: camber
yes complete truck got 2 degrees positive now no shims not sure what the camber shroud be on heard 0 degrees positive to 2 degrees neg. to 2 degrees positive so not sure where it needs to be got any suggestions
Old 10-23-2020, 09:33 AM   #9
SCOTI
SCOTI's Avatar
Re: camber
If it has POS 2° Camber w/no shims, something is possibly/probably wrong. Wrong parts combination. Assembly issue. Something.... You need to provide some additional background information.
Did you (you/someone you know) do the x-member swap?
Can you provide some pictures of the upper a-arms + where they're attached?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-23-2020, 12:57 PM   #10
dokelle
Re: camber
As far as I can tell it has a 72 cross member
