Old 10-28-2020, 01:50 PM   #1
chev-obsession
chev-obsession's Avatar
Need some battery cable advice
I did an LS swap in my 69 C10, I used the truck motor, wiring and accessories along with the F body oil pan and drivers side battery location. Since I used the truck battery cables on the drivers side with the F body oil pan I can’t use the plastic battery cable clamp that mounts to the truck oil pan. Now the battery cables lay between the engine and draw bar and would like to secure them better.
What have you guys done to secure the battery cables using the Floyd oil pan?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 10-28-2020, 05:21 PM   #2
tinydb84
tinydb84's Avatar
Re: Need some battery cable advice
You can run battery cables any where you want really. I have an Fbody pan but I ran my battery in the rear of my truck and made new cables to run to the starter.
David
Instagram: myfabguy
Old 10-28-2020, 07:05 PM   #3
chev-obsession
Just looking for advice how the guys who run he f body oil pan and secure he truck style battery cables so they aren’t resting on the frame
1965 c/10 swb
1969 c/10 lwb
Old 11-17-2020, 10:45 AM   #4
dec010974
dec010974's Avatar
i would use some clamps and run the oil pan bolt thru the clamp and secure it to the oil pan. i hope that idea helps.
dec010974 is offline   Reply With Quote
