11-01-2020, 02:17 PM | #1 |
Painting new dash pad - Landau black or Satin black
I am repainting a green dash pad that I bought for another truck to match my black interior. I bought both landau black and satin black sem paint. Does anybody have any experience with either of those and have a recommendation on which one would look best?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
11-01-2020, 04:35 PM | #2 |
Re: Painting new dash pad - Landau black or Satin black
Landau Black is my choice.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
11-01-2020, 06:23 PM | #3 |
I sprayed a sample of each on an old visor that I have and I'm waiting for it to dry to see how they compare. They both look pretty flat. We'll see how they look once they dry
11-01-2020, 07:32 PM | #4 |
Well the paint is dry on the samples and I'm not sure I can tell the difference. In fact I'm not sure either one is shiny enough. Here's some pictures but I know they won't show up very well.
11-01-2020, 10:49 PM | #5 |
What other vinyl do you have in the truck? Seats or door panels. I would choose the color that matches best as it can.
11-01-2020, 10:53 PM | #6 |
I'm not trying to match the color, I'm trying to match the glossiness of the original dash pad
11-01-2020, 10:56 PM | #7 |
It's a red truck with gray seats and black metal door panels
11-01-2020, 11:08 PM | #8 |
If you want a Gloss Black, use this..
https://www.amazon.com/SEM-15233-Glo.../dp/B002XMWA38
11-02-2020, 04:41 PM | #9 |
I'm going to pick up a can of that this afternoon and try it tonight. I am tempted to just sell the dash pad and get a new black one...
But this way I can touch it up if it gets scratched which I couldn't as easily do with the black vinyl.
11-02-2020, 08:41 PM | #10 |
That's what I would do New ones aren't very expensive and even if you sold the green one at a discount so someone would jump on it (I assume it's never been installed), then you might end up at about the same net cost as buying all the SEM paint to do the color change. Or, just hang onto the green pad, you never know when you'll need it...
11-04-2020, 09:49 AM | #11 |
Okay so I got the SEM gloss black and tried it on the visor and here are the results
11-04-2020, 09:52 AM | #12 |
So, it is fairly shiny. I'm disappointed that there's no satin or semi-gloss finish. The other two are essentially flat. I'm going to go ahead and buy a new dash pad and sell the green one but I just thought people here might be interested in seeing the results of the comparison. Here's another couple of pictures of the landau and the satin in a little bit better light.
11-04-2020, 10:13 AM | #13 |
The sheen of the paint is very dependent on the surface smoothness below it. I have sprayed door panels that had different textures based on wear and what have you, it is glossy over the smooth portions and flat over the rougher portions. It doesn't fill in like paint.
I have painted smooth vinyl with the SEM semi gloss and it is glossy.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
11-04-2020, 03:51 PM | #14 |
SWB 4x4 Collector
It will change when you use a leather conditioner. It will then put a sheen to it that you are after.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
