11-05-2020, 04:39 PM | #1 |
4-horn relay questions
I recently got a set of 4 Cadillac 2-wire horns for my truck. Does anyone know if the stock horn relay will handle the amperage from the 4 horns, or do I need to add a relay or wire the horns in pairs and use two relays? I searched the web and cannot find a definitive answer.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
11-05-2020, 06:54 PM | #2 |
Who Changed This?
Re: 4-horn relay questions
Look up that year Caddy at a parts store website and see if the relay numbers match.
11-05-2020, 08:00 PM | #3 |
11-05-2020, 09:11 PM | #4 |
I didn’t get the relay with the horns. I have read that the later horns (2-wire) don’t pull as many amps as the single wire but they are said to be not as loud also. I tested these with them temporarily connected together directly off the battery and they are plenty loud.
11-05-2020, 08:09 PM | #5 |
I've done it with the stock relay. The worst-case scenario is that you end up replacing the relay anyway. And the 4-horn setup sounds sweet.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-05-2020, 09:12 PM | #6 |
I was planning on trying it, I have a spare relay but not sure if it’s good.
11-05-2020, 11:00 PM | #7 |
I hooked them up and mocked up the mount and it worked fine. I didn’t lay on it for more than a couple seconds, time will tell how the stock relay holds up.
11-05-2020, 11:30 PM | #8 |
Who Changed This?
Are you sure you're going to need more than two seconds worth of horn blast at a time?
11-06-2020, 10:01 AM | #9 |
Probably not
11-05-2020, 11:00 PM | #10 |
It’s plenty loud, at least on the garage
11-05-2020, 11:03 PM | #11 |
They're plenty loud out on the street as well. Every once in a while I'll end up behind someone at a railroad crossing and blow the horn, just for fun.
11-05-2020, 11:35 PM | #12 |
Who Changed This?
Back when I was working for a living, I drove the 405 FWY from the 118 FWY past LAX. There was (I guess) a short-haul trucker who more than once tooted his train whistle in the Sepulveda Pass when somebody did something stupid. That 4-horn setup ain't as much as a train whistle, though I'd really like to have one for my truck. I have a little air horn that sounds like a pipsqueak who wants to be a bully.
11-06-2020, 10:00 AM | #13 | |
11-06-2020, 07:54 AM | #14 |
Ha, I have used my horn in the tunnel on the 405 northbound to the 5 going north. When traffic backs up in the afternoon during the hottest summer days, you'll hear hear em.
Back then I used my 70 Monte Carlo as a commuter vehicle. |
11-06-2020, 05:55 PM | #15 | |
I think the stock relay would drive them, but was not sure on the wire capacity. I ended up using an additional relay because it made the wiring simpler; it was easier to mount an additional relay near the battery to get the + and then run the relay + output out to the horns. The normal horn relay was then then used as the switch. |
11-06-2020, 07:06 PM | #16 |
With the 2-wire horns, the stock 14 gauge wire is fine. For the earlier one wire horns you would probably need 12 gauge.
