12-17-2003, 12:24 AM | #1 |
Frame ???s
Can anyone tell me if mid-80s bare frames are the same....
K20 - K30 2wd - 4wd single rear wheel - dual rear wheels I have a project 1985 K20 that the front of the frame is a little tweaked. It may be easier to swap it out, since I'm going to bare frame anyway.....I just need to know what trucks I can take donors from.... Thanks a bunch.... Misled |
12-17-2003, 12:58 AM | #2 |
Robert Olson Transport
as far as i know theframes for 2 wheel drive are the same and the four wheel drives are the same.
What i have learned tho is if you have an older frame you can swap out the cab mount tabs in front just make sure you use the specific mounts for the frame tab when attaching your cab
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
12-17-2003, 01:14 AM | #3 |
1 ton is different
1 ton frames are thicker than 1/2 and 3/4 on 4wd. i dont know about 2wd
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
12-17-2003, 01:51 PM | #4 | |
Re: 1 ton is different
Now the main frame rails on a Half ton are the same on 73 up between 2wd and 4wd of the same wheel base. What is different is what cradle and front cross members they get under the engine, radiator and what spring brackets they get. On 88 truck up they are even closer. The only real difference is if the get the bracket for the front Diff and spring hangers.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
