TONYP
Hummer Rims without re-centering!!
I have a set of 5 hummer rims that I've been wanting to put on my truck, re-centering them at $125.00 each plus shipping ($600.00 plus) kept them in the garage. Then as I was saving the cash I saw guys loosing the re-centered rims, they would break off or the new centers were so far off that they could not use them. So I built some spacers that lets me put them on and not have to re-center...
spacers ![]()
72 K/5 350/205 SOFT-TOP DOUG THORLEY HEADERS A/C CUSTOM REAR BUMPER http://www.socalbigdawgs.com/tr/7.18.03/DSC04290.JPG |
Collector of rusty Items
Cool.
I know a guy that runs them on dual wheel axles and they seem to work fine. I have seen spacers in wrecking yards that came off the front of a chevy dual setup that look like they would do the same thing. probelm is they are hard to find. How much do the hummer wheels cost?
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
TONYP
You can get the re-centered ones for $200.00 each, but guys have had bad luck with the centers coming off or not on center so the rim is junk, that’s why I made the spacers.
You can find stock hummer rims for $150.00 to $250.00 for a set of 5. The spacers ran $495.00. Had to have the 14ff hub turned and then the spacer was fit on it, then on the front I’m going to run DRW Dana 60 hubs…I found a set of DRW for $25.00 as everyone wants the SRW hubs, and most Dana 60 have the DRW hubs on them so they are easy
I have hummer H2 Rims for my 1970 GMC 4x4. I tried one on for size and they seemed to fit, what kind of truck do you guys have your rims on??? I would really like to use them on my truck with out haveing to much work done. thanks
TONYP
I'm putting H1 beadlock rims on my truck, the backspacing is 7-1/2" inch's so thats why I need spacers to make them work...
changed my user name.....from 72beast
