Old 11-27-2020, 11:36 PM   #1
Ultrasummer
T-5 swap woes
I have a 1968 short bed stepside. When the old 307 went, I put in a new crate 350 and a T-5 trans. The T-5 was said to be WC, the front part was out of a Camaro and the tail was from an S10. When it fired up for the first time I was so pumped. Music to my ears. When my mechanic friend told me to go ahead and put it in gear just to see if it rolls, it kept popping out of first. He looked everything over and later pulled the trans and opened it up. He said it all looks fine except 1st gear is noticeably worn. I mean ....bad. So now the search is on and everywhere we've looked, nobody has this first gear. Or those who say they have it online don't answer after waiting for the part for weeks. Anyone have any suggestions? Now I will say this, my mechanic friend has been doing the legwork of trying to track one down so I don't know who he's tried and who he hasn't. Seems we've come to a roadblock with the project.
Ultrasummer is offline   Reply With Quote
Old 11-28-2020, 12:23 AM   #2
jocko
jocko's Avatar
Re: T-5 swap woes
I typed in T-5 transmission 1st gear in ebay and found these:
https://www.ebay.com/i/124345886003?...BoCcMkQAvD_BwE
https://www.ebay.com/sch/i.html?_fro...+gear&_sacat=0
https://www.ebay.com/itm/T5-1st-Gear...UAAOSwSw1cq9OL
https://www.ebay.com/itm/1ST-GEAR-MA...oAAOSw9gRaMDNz
Of course you have to make sure of the tooth count, application, etc, but there are parts out there.
Old 11-28-2020, 08:33 AM   #3
Ultrasummer
Re: T-5 swap woes
Thanks - I'll forward this to him. Like I say, not sure what he's checked out already but I do appreciate your help.
Old 11-28-2020, 01:18 AM   #4
koolkat
koolkat's Avatar
Re: T-5 swap woes
WC? Did you have to purchase the 2 halves of the trans separately?
koolkat is offline   Reply With Quote
Old 11-28-2020, 01:46 AM   #5
gmc684x4
Re: T-5 swap woes
Have you checked out this company?
https://www.transmissionpartsdistrib...-1352-080-031/
gmc684x4 is offline   Reply With Quote
Old 11-28-2020, 07:16 AM   #6
Re: T-5 swap woes
What is WC?
Old 11-28-2020, 07:40 AM   #7
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: T-5 swap woes
Originally Posted by special-k View Post
what is wc?
x2!!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 11-28-2020, 08:25 AM   #8
3767
Re: T-5 swap woes
There are 2 types of t-5. The “WC” stands for world class. The wc trannys are supposed to b able to take more torque. Parts are still made for them and the s10 version has the tail shaft and shifter location that will work better with these trucks. If u have or locate a shop that sells tremec trannys, they can get u the correct gear. Most of them have been used/abused from time so it’s not surprising u have this problem. It’s usually 2nd that goes out.
3767 is offline   Reply With Quote
Old 11-28-2020, 08:30 AM   #9
Ol Blue K20
Re: T-5 swap woes
Thanks, I thought it was some text slang thing.
Dale
Old 11-28-2020, 10:03 AM   #10
geezer#99
geezer#99's Avatar
Re: T-5 swap woes
Lugnuts has some awesome info here on wc versus non-wc.
https://lugnutz65chevystepside.weebl...hem-apart.html
Old 11-28-2020, 10:34 AM   #11
Grumpy old man
Grumpy old man's Avatar
Re: T-5 swap woes
5speeds.com
https://www.youtube.com/watch?v=PxYwNxCzguE
https://www.youtube.com/watch?v=pEqWgzbE8ps
Old 11-28-2020, 11:39 AM   #12
LockDoc
The Older Generation
LockDoc's Avatar
Re: T-5 swap woes
Then there is our member "Brad" that posted this info. It is in the "FAQ" section on here.
http://67-72chevytrucks.com/vboard/s...d.php?t=438224
The full thread is here:
http://67-72chevytrucks.com/vboard/s...d.php?t=313954
LockDoc
Leon
