Quality H-Light switch for 63 C10 ?
The new aftermarket switch I installed about 10 yrs ago has failed.
The re-pop vendors have them for about $25 and NAPA has one, from the (once) respected name Echlin for $70 Can anyone justify the higher price?
`63 C-10 Shortwide Roller 305 LT1 cam, Eddy 500 T5 |
It's Better With Nitro
Re: Quality H-Light switch for 63 C10 ?
I run a Ron Francis headlight switch in my builds. I think you can get them from Summit Racing for around $45.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Thanks, do they accept the OG harness plug ?
I believe they do. Give them a call.
Thanks guys, I went on-line Summit and found nothing from Ron Francis or the make/model OEM search that convinced me.
I have a Standard on the way from RockAuto.
![]() ![]() ![]() Join Date: Jan 2018
I recently had to purchase a new headlight switch for my 63. I went with a Standard Motor Products one and ordered it from Amazon because the same part was about $40 more at the local parts store. It has worked great for the past 2 months that I've had it in. My old switch was hard to make it stop on the parking light circuit because the detents were not that great, but the new switch is real easy to stop in all 3 positions
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Morning all,
Just received my headlight switch for my 65 C10. It's a Suntex brand ( $14.95). It felt and looked cheaply made, and was faulty right out of the box. I went to my local NAPA store and got an Echlin ECH HL6554 switch ($22.99). The quality looked and felt much better and works great. Time will tell if it's a good one or not. Both these switches were made in Taiwan. I do plan on doing the headlight relay mod in the future. |
#9 | |
Moderator
![]() ![]() Join Date: Aug 2011
I use 2 relays one for low beam and one for high. When doing this the only job of the headlight and dimmer switches is to supple a small amount of current to energize the relay. The energized relay sends full voltage from the battery straight to the headlamp. It's not unusual to have a voltage loss through the switches, multiple connectors and lots of wiring especially with older wiring.
Moderator
Oh that one. I have installed relays for my headlights as well. Your right, it's a great idea.
I wouldn't expect better quality than NAPA and the relay bits are a nonsequiter...
Same headlight switch fits 1957-1963 Chevrolet cars. Maybe hitting the junkyards if you have any around your area might turn up an original Delco switch. They also fit some Buicks as well. Here is a list of vehicles that use the same switch:
BUICK ELECTRA 1959-1963 BUICK ESTATE WAGON 1960-1962 BUICK INVICTA 1959-1963 BUICK LESABRE 1959-1963 BUICK RIVIERA 1963 BUICK SKYLARK 1961-1963 BUICK SPECIAL 1961-1963 BUICK WILDCAT 1962-1963 CHEVROLET BEL AIR 1957-1963 CHEVROLET BISCAYNE 1958-1963 CHEVROLET C10 PANEL 1962-1963 CHEVROLET C10 PICKUP 1960-1963 CHEVROLET C20 PICKUP 1960-1964 CHEVROLET C30 PICKUP 1960-1964 CHEVROLET CHEVY II 1962-1963 CHEVROLET CORVAIR 1960-1963 CHEVROLET CORVETTE 1957-1963 CHEVROLET DEL RAY 1958 CHEVROLET EL CAMINO 1959-1960 CHEVROLET IMPALA 1958-1963 CHEVROLET K10 PICKUP 1960-1964 CHEVROLET K20 PICKUP 1960-1964 CHEVROLET P10 SERIES 1960-1963 CHEVROLET P20 SERIES 1960-1963 CHEVROLET P30 SERIES 1960-1963 GMC 1000 SERIES 1961-1963 GMC 1500 SERIES 1961-1963 GMC 2500 SERIES 1961-1963 GMC 3000 1961-1963 GMC 3500 1961-1963 GMC G1000 SERIES 1963 GMC PB1000 SERIES 1961-1963 GMC PB1500 SERIES 1963 GMC PB2500 SERIES 1963 GMC SUBURBAN 1960-1963 GMC TRUCK 1960 GMC V3000 FORWARD CONTROL 1961-1962 Info from Rock Auto. |
