Old 12-07-2020, 03:21 PM   #1
cericd
cericd's Avatar
Factory Style Lug Nuts
What type of lug nuts were used from the factory on 1971 C/10's with factory steel wheels? Are they something that would be readily available at a parts store or would I need to order online?
I'm using conversion axles on the rear of my 1970 and according to this thread, http://67-72chevytrucks.com/vboard/s...d.php?t=564907, I need to use Dorman wheel studs, part number 610-298.1. Would they be correct to use with factory 5-lug 4-nub steel wheels?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 12-07-2020, 07:16 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Factory Style Lug Nuts
I'm pretty sure they are 1/2x20 nuts.
Aimco number 5516
Wheel stud size is 1/2"- 20
Rotor size:
Heavy duty type, 1.250" thick
12.00" diameter
5 x 5" bolt pattern
Yes they are a standard size that all parts store should have in stock. Even the chrome ones to dress up the wheel a bit.
https://www.performanceonline.com/19...bolt%20pattern
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
