12-12-2020, 10:05 PM | #1 |
low n' slo
Stock wiring
finally got a donor truck for my ls swap. i never considered rewiring my suburban, but what are u swap guys doing for wiring. im not referring to the engine harness, i mean the actual truck wiring. im thinking of getting the EZ wiring 21 wiring kit, but unsure if its needed with an ls swap. i havent really tested my original wiring, but figured for their price it would be a good idea to replace my old original one. or are most just using thr stock truck wiring?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-12-2020, 11:13 PM | #2 |
Re: Stock wiring
If the factory wiring to the rest of the truck, everything but the engine, is bad, then you will need to do something about it. An LS swap wiring harness just runs the engine.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
12-13-2020, 09:00 AM | #3 |
low n' slo
Re: Stock wiring
i figured fresh wiring would be a plus for the newer motor. what stock wiring does the ls motor tie into?
12-13-2020, 01:30 PM | #4 | |
Re: Stock wiring
There are other wires like gauges, torque converter lock up, and fuel pump that will need to be hooked up too, but most of that doesn't have any affect on the vehicle harness.
12-13-2020, 07:22 PM | #5 | |
low n' slo
Re: Stock wiring
12-13-2020, 09:09 AM | #6 |
Re: Stock wiring
I've been reading up on swaps, and once the LS side has been done, there is only 4 wires I think that need to be hooked up to the truck. So the trucks stock wiring should be fine. Prolly have to change some sensor plugs or similar to use the trucks wiring to fit on the LS plugs.
12-13-2020, 12:21 PM | #7 |
Re: Stock wiring
You can cut the top of the oil sending unit and tap it to fit your oil sending unit tube
Easy to drill passanger side head for temp sending unit That is unless you plan on going dakota guages with the blm modual to take guage info from the ecm Question is how hood are you at wiring as those kits are other then the bulkhead 100 % do it your self M&H makes factory style harness like original that is modular that you can tailor to replace only the sections that are really rough |
12-14-2020, 05:44 PM | #8 |
Re: Stock wiring
On my 68 C10 LS swap I used a Painless universal kit for the chassis. Howell Fuel Injection for the LS and trans harness.
I don't trust 50 year old wiring. I cut the original chassis connectors off and then used them with the Painless harness as needed. LS swaps need good connections and really good grounds to function properly. Good luck with your swap. |
12-14-2020, 08:20 PM | #9 |
low n' slo
Re: Stock wiring
they seem decent to me?
12-14-2020, 09:07 PM | #10 |
Re: Stock wiring
I would probably consider replacing that harness, there is an awful lot of rust on the fuse connectors which most likely wont clean off and could cause problems,
12-14-2020, 09:40 PM | #11 |
low n' slo
Re: Stock wiring
ya i never noticed it until the flash went off on my camera, plus i hate those glass type fuses. i think i will try the EZ Wiring 21 circuit kit
