Old 12-19-2020, 04:03 PM   #1
Portland68
Cross member identification - 4x4 L6
Double checking this cross member is correct for a 292 K truck (could you even get a 230 or 250 in a 4x4?)
Looks correct from searching the forum but I wanted to be double sure before I pull it. Thanks!
Portland68 is offline   Reply With Quote
Old 12-19-2020, 04:17 PM   #2
bluek5
bluek5's Avatar
Re: Cross member identification - 4x4 L6
Looks like a V-8 missing the right side perch to me. Pictures I found on this site .
bluek5 is offline   Reply With Quote
Old 12-19-2020, 06:12 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Those are my pictures. They are crossmembers for L-25 292 L6s in 4x4 trucks. As far as I know, only the 292 needed a K-truck crossmember. I could be wrong. The orientation of the 292 X-mbr was somewhat diagonal, with Right Hand leading.
250s were the base line engine for Blazers, unless a V8 was specified. After '67, GM did not equip trucks with 230s.
Old 12-19-2020, 08:03 PM   #4
landarts
landarts
First two picture on the post show from a top view of a K10 /K20 V8 crossmember and second photo shows the 292 6 cylinder crossmember.
https://67-72chevytrucks.com/vboard/...&postcount=114
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 12-19-2020, 09:35 PM   #5
'68OrangeSunshine
I looked at your other post about swapping a 292 in for an SBC.
Neat.
You asked about 292 fan shrouds: Only on Factory A/C trucks were fan shrouds installed. And since the 292 was usually a workhorse motor in a fleet truck, that was a very rare option. Most L6s just had the Finger Guard over the fan.
Old 12-19-2020, 05:31 PM   #6
57taskforce
All about them K’s
57taskforce's Avatar
I agree, looks like a small block setup.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is online now   Reply With Quote
Old 12-19-2020, 05:35 PM   #7
gmc684x4
Yes that is a small block or 250 6 banger cross member
292 will take a different unit
gmc684x4 is offline   Reply With Quote
