Old 12-19-2020, 07:41 PM   #1
Stephen717
Stephen717's Avatar
drive shaft length
ok so I have a 350 that I have most of the parts to build and I am going to put it in my truck in place of the 250 I6, for now I am retaining the Saginaw 3 speed trans but am eventually going to put a 4 speed behind it. figured I could save up to get a good transmission once the truck is on the road and later on I could put a gearvendors over/underdrive unit in the truck. my question though is when the 350 gets bolted into the truck will I need to increase the length of my driveshaft or does the 350 sit far enough back that its not an issue? any help would be greatly appreciated.
thanks
Stephen717 is offline   Reply With Quote
Old 12-20-2020, 09:08 PM   #2
SeanB242
SeanB242's Avatar
Re: drive shaft length
Should be same location.
SeanB242 is offline   Reply With Quote
Old 12-20-2020, 09:45 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
I would leave the transmission in the original mounting spot and mount the 350 where it needed to go if that makes sense. I don’t play with two wheel drive trucks much, so I can’t tell you for sure which set of frame holes the engine crossmember would need to be in for it to work like this.
Tyler
Old 12-21-2020, 05:00 PM   #4
Stephen717
Stephen717's Avatar
Thanks guys, that should make things a bit easier for me
