Old 12-21-2020, 10:38 AM   #1
kglowacky
wiper blades
replacing my wiper blades on my 78. currently has 18 inch all books at the parts house say 16 inch. Anyone have a part after market part number . The parts houses are struggling because I have the flat blade attachment type. Who knows I may have a set off some other car that has been changed over the years.
kglowacky is offline   Reply With Quote
Old 12-21-2020, 11:02 AM   #2
Bandit130
Bandit130's Avatar
Re: wiper blades
I use 18" blades from Walmart with the OE bayonet style arms. The blades will slide on.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 12-21-2020, 05:30 PM   #3
kglowacky
Re: wiper blades
went to walmart. They had a rainx blade that would work BUT it seemed a little loose on the fit. I was afraid if it let loose I would need a new windshield. Anyone know of a supplier that sells the original SS blades and rubber, or someone that sells just the insert rubber so I can just replace the rubber. Thanks
Old 12-23-2020, 09:01 AM   #4
Re: wiper blades
I could never find a flat blade style wiper blade assembly that was worth anything. They always seemed too loose. I switched my wiper arms over to the 85-87 style with the bayonette style mount. No issues at all now with loose blades. My truck was an 81, but it should work with yours also.
Old 12-23-2020, 12:05 PM   #5
cadillac_al
Re: wiper blades
I always thought the older style was bayonette, oh well. I always buy Anco winter blades and they slip right on the stock arms easily. I would assume the summer Ancos do too. I got some cheapo NAPA wipers a couple years ago. They don't work that great but they do seem to fit snug and haven't lost one.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-23-2020, 12:35 PM   #6
Re: wiper blades
You might be right on the names, I forgot which is which, but do like the newer style better
Old 12-23-2020, 04:06 PM   #7
kglowacky
Re: wiper blades
that's the issue i am having. the blades being sold at walmart and orileys will snap on but they just don't fit right. they are loose and i don't want to take the chance. years ago i could just buy new rubber strips and replace them. oh the good old days. where have they gone.
Old 12-23-2020, 05:06 PM   #8
1976gmc20
Re: wiper blades
It makes no sense now in these days of "Recycle!" that you have to replace the whole damn assembly instead of just the part that wears out
Back in my service station days I must have replaced thousands of those rubber wiper blades with the little metal strip.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 12-31-2020, 08:18 PM   #9
Pontiac1976
Pontiac1976's Avatar
Re: wiper blades
That one way to do it as
Or you could just order from rockauto 16" is what 73-87 GM blades where. But a 17" works nice but hard to find clears a little more window. 18" works clear more window but flops around the most and in winter put more wear on the motor.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 01-01-2021, 01:18 PM   #10
Axle
Axle's Avatar
Re: wiper blades
I did the same, pin mount is so much more secure, I had too many flat style break off.
But what I'm finding now (DO NOT buy Tricos unless they are exact fit; garbage that not lock on) is that other than exact fit blades, nobody makes a decent retainer for anything but the modern hook style. Trico used to be my goto back in the 80s and 90's, so didn't give it much thought when I saw them. One did not last an overnight freeze, as soon as the snow brush hit it it went all cockeyed. Had to dig out my old wiper blades to get going.
Axle is offline   Reply With Quote
Old 01-06-2021, 09:26 AM   #11
LT7A
Re: wiper blades
After extensive searching I did find where you can buy just the rubber strips online. I would do this if I had the original blade housings on any of my trucks, but I don't. The rubber pieces are just as costly, if not more than buying them with the rest of the blade. Sorry I can't point you directly anywhere, you'll need to do a search. I think they may call them wiper blade inserts.
LT7A is online now   Reply With Quote
