Active Member
![]() Join Date: Dec 2019
Assortment of parts
I知 trying out the picture with labels thing! Here is a big assortment of parts I知 getting rid of. All the prices you値l have to add shipping to.
1) Heater box (nice) $20 2) Factory headliner $10 3) Pollack fuel selector valve (new) $10 4) 4 blade fan from 69 non ac $20 5) Jack Hardware $5 6) Temp Gauge $5 7) GMC 3500 V-Eight emblems $30 pair 8) GM seatbelt $20 9) complete original bed hardware longbed (might be missing a couple bolts or washers $20 10) Headlight trim $5 11) Door panels $40 12) hood hinges $20 13) washer fluid bracket $10 14) set of horns $15 15) smog canister and bracket $30 16) Manual throttle setup with bezel $50 17) NP 205 shifter with bolt $10 18) Blazer rear fender supports $10 19) Carb $10 20) Hood Hinges $20 21)Fresh air doors $5 22) Door latch catch $5 23) Door latch mechanism $5 24) Fuel tank mounting hardware (complete) $5 25) 69 cab wiring harness (no ac) $15 26) New Stewart Warner Tach $20 |
Re: Assortment of parts
I will take these:
5) Jack Hardware $5 6) Temp Gauge $5 21)Fresh air doors $5 Shipping to 44657 - thanks |
![]() Join Date: Jan 2007
I will take the shifter and the harness #17- #25
Active Member
Ok sounds good, I値l try to ship everything flat rate boxes to keep it the cheapest. I don稚 have PayPal so everyone knows, I have some of the money apps on my phone as well as check or money order of course. Sorry for the hassle.
![]() Join Date: Jul 2017
I値l take the manual throttle set up with bezel if it is complete with gas petal parts. Is it the 72 style?
Active Member
The manual throttle is from my 69, I have the pedal piece and the linkage that goes with it.
Sounds good, I値l take it. If 69 it should also include the clip/grommet where the cable goes through the firewall?
I値l also take the horns if they work, and the shifter if your other buyer falls through. Interested in the carb, what are the numbers on the carb? Regards, Jonathan |
Active Member
Pictures for Jonathon
Moderator
![]() Join Date: Jun 2008
I値l take the door latch. Shipped to 95355
Posted via Mobile Device |
![]() Join Date: Jul 2018
I’ll take hood hinges #20 if they are tight, which ever set it tightest
Shipping to 06524 Steve |
I’ll take the horns #14
95207 Last edited by Rich rodriguez; 12-24-2020 at 11:01 PM. |
Passing on the carb
![]() Join Date: Dec 2009
I’ll take the carb
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
![]() Join Date: Jun 2005
I will take the tach pending better pics
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#15 |
Active Member
I知 writing everyone down, just gonna take tomorrow off then I値l get back to you Saturday
#16 |
I値l take #11, door panels.
Shipping to 34223 Thanks Posted via Mobile Device |
#17 |
![]() Join Date: May 2011
I'll take #8 and 17 shipped to 17225.
#18 |
Active Member
![]() Join Date: Nov 2002
Can I get next in line for the manual throttle #16 ?
Thanks Don brace
Don Brace 55 Nomad 56 Nomad 58 Impalla Coupe 58 Bel-Aire 4D HT 61 Impala CVRT 409 4 SP 2- 71 Longhorns Always looking for old toy trains, Juke boxes Pin ball and game machines. |
#19 |
Active Member
Pics of tach for 70stovebolt. Iツ知 working on getting pms with shipping quotes to everyone.
#20 |
Junior Member
![]() Join Date: Oct 2017
How much for the gauge cluster. Could you post a close up of the front?
#21 |
low n' slo
![]() Join Date: Mar 2009
what year is the headlight trim for? im assuming 69 since most of the other parts are. looking for a set for 67. thanks
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#22 |
Active Member
These are all pending sold
(5) jack hardware (6) temp gauge (8) seatbelt (9) bed hardware (11) door panels (14) set of horns (16) manual throttle setup (17) shifter (19) carb (20) hood hinges (21) fresh air doors (22) door latch (25) harness (26) Tach |
#23 |
Active Member
Kev the headlight trim is from a 72
#24 |
low n' slo
i thought they looked a little different. thanks for checking
#25 |
Yes on the carb. Replied to your pm!
