Old 12-31-2020, 05:59 PM   #1
dodge8mm
NV4500 damper
I am looking at getting a NV4500 from a 1993 Chevy 2wd to put in my 1972 GMC to replace the SM465. The NV has a damper or such on the rear of it. Is that needed, can it be replaced with something else? Sounds like it is very hard to remove for a refresh.
And, has anyone ever used the stock shift knob on a NV4500 adding 5th to the knob? I'd rather have the factory knob over the NV knob. Thanks for the help.
dodge8mm is offline   Reply With Quote
Old 12-31-2020, 07:50 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: NV4500 damper
Your NV4500 looks different than mine. Mine has a longer tailshaft and does not have the damper.
Here is my install using all of the stock bell housing and clutch components from the SM465.
http://67-72chevytrucks.com/vboard/s...d.php?t=673588
I did not use the '72 shift knob but I see no reason it couldn't be used, it may take some modification to the threads.
LockDoc
Leon
Old 12-31-2020, 07:58 PM   #3
jarrodblake
jarrodblake's Avatar
Re: NV4500 damper
The damper comes off with the u joint flange. Its comes off super easy. just remove the nut and slide it off.
Mine 95 chevy nv4500 with a cummins bellhousing.
IMAG2768 by jarrod vanwinkle, on Flickr
jarrodblake is offline   Reply With Quote
Old 01-04-2021, 12:22 PM   #4
dodge8mm
Re: NV4500 damper
Perfect, and is the throw out bearing the same from the 465 to 4500? Or do I need the newer model's bearing.
Old 01-04-2021, 01:32 PM   #5
LockDoc
LockDoc's Avatar
Re: NV4500 damper
Mine was the same, but since that trans is a little different than mine I can't be sure. I'm betting it is though. Maybe Jarrod can answer for sure, if he tried it.
LockDoc
Leon
