Old 01-05-2021, 04:40 AM   #1
ChevyRacefan
ChevyRacefan's Avatar
Front A-arm U-bolts
Hello:
At what point is it best to move to the (iirc) '73 and up bigger U-bolts.
I am going to assume, today's tire compounds & wider tires Put more loading on them in a turn.
At what point is it a good idea?
Does a street truck that get some spirited driving but not Auto crossing it.
Does lowering truck come into play on loading?
ChevyRacefan is offline   Reply With Quote
Old 01-05-2021, 11:16 AM   #2
SCOTI
SCOTI's Avatar
Re: Front A-arm U-bolts
If you're under the truck & doing upgrades, it's worth it. As mentioned, better tires these days & upgraded suspensions equal additional lateral grip (stress) so it's a good idea. The size was upgraded when disc brakes came out so that should be a factor as well (when upgrading to discs on a drum truck).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-05-2021, 01:05 PM   #3
68 P.O.S.
It's best to do it now. it's only a matter of time before they break. The original bolts were 7/16" and some had 1/2". Both had a penchant for snapping when reversing with the steering wheel at full lock. I've had it happen before. Upgrade to the 9/16" bolts and you'll be set.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 01-06-2021, 09:17 AM   #4
67C10Step
67C10Step's Avatar
While I had my front end blown apart I went ahead and did the upgrade. Easy as pie. Had to open the holes in the cross member a bit but not much. Peace of mind if you are already under there working.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 01-06-2021, 10:43 AM   #5
ChevyRacefan
Thanks guys.
